<<  7    8    9    10    11    12    13  >>
Author: Subject: Rosco's haynes Build
CosKev3
posted on 7/10/15 at 03:49 PM Reply With Quote
Originally posted by Johneturbo
Amazing build, top quality fabrication
I only got to page 7, as from page 8 none of your photos are coming up
Must be your laptop/Internet connection etc,all pics showing fine on mine
Johneturbo
posted on 7/10/15 at 03:51 PM Reply With Quote
Very odd, as the photos on the last page are showing up. but not from 8 onwards!
ETA ok seems to be ok now! laptop throwing a tantrum!
[Edited on 7/10/15 by Johneturbo]
Rosco86
posted on 9/10/15 at 08:13 PM Reply With Quote
Thanks,
I'm sticking with these switch guards as they weren't the cheapest!
My Build Thread
Rosco86
posted on 9/10/15 at 08:23 PM Reply With Quote
Right update time, been bitting and bobbing all week really
Rear lights temporarly mounted and wired to the front
Makeshift dash sorted so I can start to get things wiried
Battery cables done
I'm using these terminal bars for my wiring
Toggle switches for my dash
New gear lever made
Also made a bracket for the starter relay
My Build Thread
theduck
posted on 9/10/15 at 08:48 PM Reply With Quote
I love this build. Would love to see it one day.
Rosco86
posted on 11/10/15 at 08:25 PM Reply With Quote
Cheers pal, everything will be covered when it's finished lol
My Build Thread
Rosco86
posted on 11/10/15 at 08:32 PM Reply With Quote
Almost two full days of wiring!
All dash wires into terminal rails
These are the ends, crimp forks soldered on
Two 13 way plugs fitted on the end of the bike loom and fly leads out the other side to the rails
Engine loom in position and getting neater
Water pump removed, need to block the hole in the block, I'm going to run an electric water pump
And that's it, doesn't look a lot, got a few more plugs to fit and get my switches mounted then I will be linking the rails together, I might get rid of the rails when it's all wiried but I will see, I did it this way as its all laid out and I'm hoping it will be easy to keep track of
My Build Thread
Adamirish
posted on 11/10/15 at 08:38 PM Reply With Quote
Wiring is the part of any build that scares me! You seen to have it under control though. Love it!
MK Indy 1700 Xflow
CosKev3
posted on 12/10/15 at 07:17 AM Reply With Quote
Awesome as usaul!
I can't remember seeing your brake light switch?
Only reason I mention it whilst your sorting wiring I would look into fitting a switch on the pedal rather than a pressure one in line.
One of my winter jobs,as I've found you can be braking without the lights coming on,you need to press pedal pretty hard to get lights on.
Last thing you want in one of these is some dippy driver in a Chelsea tractor rear ending you!
Rosco86
posted on 12/10/15 at 11:20 AM Reply With Quote
cheers,
yeah ive ordered a little limit switch, ive just got to work out how to mount it, i should of done it when i drew the pedal box up but didn't think, yet another job to do!
My Build Thread
Rosco86
posted on 22/10/15 at 08:58 PM Reply With Quote
Right small update, had to work on the house all weekend!!!
Water pump blank bung made
Bolted up
Also made a reducer to join these two pipes
Switches fitted in temporary dash, position not final
Relay bracket fitted and leads finished
My Build Thread
Rosco86
posted on 24/10/15 at 09:30 PM Reply With Quote
Got my electric water pump fitted and my painted pipes back on
Oh and I had to bore out some rubber grommets so the pipe fitted snug
Me and my Dad spent all day wiring, we got the indicators working and the tail lights, and got the digi dash powered up, hopefully another few weekends and the bulk of the wiring should be done! We might try and get the engine started again next week to make sure it still runs!!!
[Edited on 24/10/15 by Rosco86]
My Build Thread
Rosco86
posted on 10/11/15 at 09:04 PM Reply With Quote
Right, I've been busy on the wiring for the last few weeks, it's all done but needs tidying when I get my dash etc
I've taken it all off now as it was in the way a bit
Also stared on my tunnel panels
I'm using wing beading to brake the edges
Also got my hard pipes rivited in place
Oh and one last thing.............
My body work has been ordered!!!!! Yay
My Build Thread
rdodger
posted on 10/11/15 at 10:05 PM Reply With Quote
Neater than a neat thing being neat!
Tidy too!
Adamirish
posted on 10/11/15 at 10:09 PM Reply With Quote
After seeing your pictures one thing puzzles me. Where exactly are you going to mount the Henry? And what are the performance benefits?
Still looking ace mate. Keep it up!
MK Indy 1700 Xflow
Rosco86
posted on 11/11/15 at 08:45 AM Reply With Quote
haha cheers guys!
My Build Thread
Rosco86
posted on 14/11/15 at 05:56 PM Reply With Quote
Right full day again today, first job, I wanted to add a throttle return spring so the pedal felt a bit harder
And it turned out like a dream
Then made a sump plug to fit my oil temp sensor, fitted it with thermal cpu compound to try and help heat transfer
Bleed hole
Then got the engine bay loom wrapped back up with pvc loom tape
Then finished fitting my tunnel panels, I decided to use rivnuts and bolt them, I've not used a lot as I'm going to use dots of sealer to stop them rattling
Loom dropped back somewhere near
My Build Thread
Adamirish
posted on 14/11/15 at 10:40 PM Reply With Quote
The most over engineered throttle return Spring I have ever seen! Love it! I guess it's somewhat adjustable too which would be useful. Great work mate, keep it up!
MK Indy 1700 Xflow
Rosco86
posted on 16/11/15 at 08:12 PM Reply With Quote
Cheers pal, but in all honesty it only took about 30mins start to finish
My Build Thread
Rosco86
posted on 16/11/15 at 08:18 PM Reply With Quote
Pedal back stops done
Then sorted my brake light switch, took me a while to hatch a plan but I think it will work ok
Nice and adjustable
Then a switch will be mounted above so as soon as the pedal is touched it releases the switch
That was yesterday, then tonight I've made a little battery tray on my dads cnc
In place, just needs a little fitting
The clamp will be bolted from underneath the floor and hold everything in
My Build Thread
christim
posted on 16/11/15 at 09:09 PM Reply With Quote
Almost a shame it'll all soon be covered up in bodywork...every piece really top quality
CosKev3
posted on 16/11/15 at 09:31 PM Reply With Quote
As above,spot on
One thing though,have you sat in the passenger seat with the battery where it is?
If anyone that's going to be a passenger is 6 foot+ they won't thank you for fitting the battery there!
[Edited on 16/11/15 by CosKev3]
Rosco86
posted on 2/12/15 at 07:51 PM Reply With Quote
As above,spot on
Cheers chaps!
No I've not to be fair, I will chuck a seat in and try!
My Build Thread
Rosco86
posted on 2/12/15 at 07:54 PM Reply With Quote
Right well ordered my shocks from protech shocks, what can I say! A perfect service! Even did them all black for me! Well happy
My Build Thread
ste
posted on 11/12/15 at 11:04 PM Reply With Quote
Rosco, this is a lovely build, one of the best I've seen by far.
One little thing for you though, you need to have the horns pointing down or level so they don't fill with water. Just fitted mine this week and the pack had that warning on.
Do you take orders on the engraved chassis numbers?
ste
