<<  9    10    11    12    13    14    15  >>
Author: Subject: Rosco's haynes Build
AlanH
posted on 7/3/16 at 09:58 PM Reply With Quote
Just read you thread Ross. Cracking work, an impressive example of what can be achieved.
A
Digimon
posted on 8/3/16 at 10:18 AM Reply With Quote
Congratulations Ross
JSArmstrong
posted on 10/3/16 at 08:09 PM Reply With Quote
What a fantastic and inspirational build Rosco! And congratulations!
Rosco86
posted on 12/3/16 at 08:09 PM Reply With Quote
Cheers guys!!!
I've got a few hours here and there and got a bit more done, also reached a bit of a milestone
Made a bit of a bracket to mount my horns in a better position
A bracket to support the middle of the rear tub
Then today got the wheels on ready for the floor!
There was 8 of us and lifted it down a doddle, looks so much better on the floor!
Then my mate called by with his corner weight scales
And I'm so happy with the weight! I put everything in the car that's left to fit, only things missing is seats and harnesses, oh and a tank of fuel
Weight was 507kg so real happy with that, it's full of oil and coolant, so looking like 550kg max wet with the key in, no rubbish dry weights here!
Oh also the car was heavy on the left so should be nice when I get in, or heavy on the right!
My Build Thread
CosKev3
posted on 12/3/16 at 10:12 PM Reply With Quote
Mint
Word of warning when you first go to fill it with fuel,my hose is exactly the same as yours from filler to tank and its puss to put fuel in!
You gets loads of splash back and can't have the fuel going in more than half speed
[Edited on 12/3/16 by CosKev3]
Rosco86
posted on 18/3/16 at 09:49 AM Reply With Quote
Originally posted by CosKev3
Mint
ah ok mate, might get a cool jerry can then, just so i look cooler
My Build Thread
Rosco86
posted on 21/3/16 at 11:27 PM Reply With Quote
Bit of a late one tonight but I need to press on and get it finished!
Finally fitted my dash switch guards and label plates, well happy with it!
My Build Thread
CosKev3
posted on 22/3/16 at 08:07 AM Reply With Quote
Nice
Not sure if it's been mentioned already,but seeing as you have no steering lock fitted you will need a second security device for IVA.
Rosco86
posted on 27/3/16 at 03:16 PM Reply With Quote
Nice
Cheers pal, yeah Ive read the iva manual and I think the ignition key counts as one and the factory engine imobilizer will count as the second, not 100% tho
My Build Thread
Rosco86
posted on 27/3/16 at 03:57 PM Reply With Quote
Got a few more jobs done
The front of the car was on the floor on the bump stops so had to make some plastic spacers
Sorted a brake light switch out
Next up a job I've been putting off for some reason, front indicators,
First up drilled a small hole to check it looked about right
I had to open some grommets up as the fiberglass is quite thick
Glued some indicators into some carbon tube
These will push in either side and join with this and the wires will come out the sleeving
My mate lent me his laser alignment gear, and left me to it!
Suspension all tight and cycle wing brackets fitted
My Build Thread
CosKev3
posted on 28/3/16 at 09:33 AM Reply With Quote
Getting a bit repetitive now saying 'awesome work' 'looks spot on' etc!!!!!
Really looking forward to seeing this in the flesh hopefully this year
What's the score with aligning it with no springs on the dampers?
Surely the alignment will be out again once the springs go on and you set up the ride height?
Also if that's the height your going to be running the car it doesn't look like you will have enough travel on your dampers,it will surely be bottoming out the damper under compression?
Rosco86
posted on 5/4/16 at 08:36 PM Reply With Quote
Cheers mate, yeah hoping to get it finished soon!
No springs on as I've got the chassis sat on blocks at the ride height I'm going to run, 4" front 5" rear, I can't really corner weight and set ride height till it's all finished and wanted to get the alignment somewhere near,
No springs so I can check the bump steer,
After thinking about it your proberly right about the front travel, think I'm going to lift it up a bit, say 5" front, 6" rear
That will mean 4" front travel and 4" rear travel when it's on the bump stops, sound ok?
My Build Thread
Rosco86
posted on 5/4/16 at 08:46 PM Reply With Quote
Bit of an update
Front grill glued in
Got some wiring tidied up, still more to do but getting there, refitted the bulkhead to see how it fits
Fitted the fog and reverse lights
And yes that is my garage floor paint on my tyre grrrr
Got the rear lighting wiring almost finished, surprising how much kit you need!
Fuel breather fitted
Made a dibond divider to separate the footwell from the battery
My Build Thread
Rosco86
posted on 19/4/16 at 08:21 PM Reply With Quote
Bit more of an update,
Lifted my ride height up a bit, 5" front 6" rear, got all my camber and toe adjusted
Then checked the bump steer, to start with from ride height it full bump it was toeing in 4mm a side
After sliding the rack up a bit on the slots I've now got
0mm total toe at full droop
2mm total toe at ride height
2mm total toes at full bump
Which according to my mate who lent me the lasers should be ok
Just need to put the springs back on the shocks, and get the ride height correct and then corner weight it when it's finished and double check the alignment
Next up, I've filled my iva forms out and sent them off! Woo hoo
I have been on with other bits and bobs but still got a bit to do, I need to get cracking!
My Build Thread
hkp57
posted on 20/4/16 at 09:50 AM Reply With Quote
Its a great looking car and its a credit to you.
one question, does it annoy you as it does me that the Toyo R888 r tread patterns are not handed?
I just got a set and bugs the life out of me when you look at the car from the front and it looks like a tyre is on backwards knowing its not.
How hard would it have been for Toyo to tool up two molds
Fleet
SKC Raptor R - Hayabusa
Toyota C-HR Hybrid Limited Edition
Honda VFR1200 CrossTourer
DCT
Marlin Roadster 1800
Mercedes Vito 116 Sport
Rosco86
posted on 24/4/16 at 07:05 PM Reply With Quote
Cheers pal, yeah how did you guess? Drives me nuts,
My Build Thread
Rosco86
posted on 24/4/16 at 07:13 PM Reply With Quote
Got a bit more done this weekend, not as much as I would of liked but it's slowly getting there
My mum sowed me a hand brake gator up
Which spured me on to make a padded centre for my wheel
And for people who think I don't bodge things
Made my vin plate
Finished the wheel arch light plinths, these took loads of work but they have turned out perfect,
Rear wiring loom all finished now, just a bit left to sort behind the dash
My Build Thread
Rosco86
posted on 25/4/16 at 07:45 PM Reply With Quote
Got a little job that was nagging me sorted tonight
The joint of the front indicator carbon tubes
Mk1 that I wasn't really happy with, wasn't really solid enough
Mk2 bit of nylon turned up and two bolts through the plastic into the tube, looks less of a bodge to
Well happy, as I've had the tube ready for the job for ages!
My Build Thread
Rosco86
posted on 30/4/16 at 04:31 PM Reply With Quote
Good half a day today trying to soft the wiring mess out, it's getting there but just needs a little bit more sorting then I will be able to live with it I think
My Build Thread
CosKev3
posted on 30/4/16 at 05:25 PM Reply With Quote
I'm no expert! But yeah that sounds better
You've done something controversial with the rear arches
I know they fit both ways,but IMO yours are on back to front
Rosco86
posted on 30/4/16 at 05:51 PM Reply With Quote
Oh god, I just thought they went that way round, bit to late now, do you think it looks rubbish? Stressing now
My Build Thread
CosKev3
posted on 30/4/16 at 05:59 PM Reply With Quote
Nothing on your car looks rubbish m8!!!!
I've just got it in my head the way they go,but they fit both ways so it's up to the builder tbh which they prefer
CosKev3
posted on 30/4/16 at 06:04 PM Reply With Quote
CosKev3
posted on 30/4/16 at 06:06 PM Reply With Quote
I just think the angled part looks better at the front,and flatter part on rear
Rosco86
posted on 30/4/16 at 06:26 PM Reply With Quote
Yeah your right I think they do look better that way round, too late now though
My Build Thread
