Author: Subject: Honda S2000 engine with large sump, baffle & loom
unijacko67
posted on 29/10/14 at 10:52 PM Reply With Quote
Honda F20c S2000 engine and loom package.
Would suit rally, kit, sprint, track car.
Only done 36,803 miles.
For sale is my low mileage Honda 2007 S2000 engine with modified big wing sump (holds an extra 1.5 litres without raising the oil level.
1997cc.
258 bhp, still in the car and can be viewed/tested, no time wasters please.
Dyno sheet available.
The sale includes;
Full stripped down modified loom using all s2000 ancillaries.
Alloy bespoke tank with s2000 fuel pump and fuel pipes.
Indicator and light switches.
Wiper motor switch and curcuits.
Duel horns, circuits & switch.
Lighting circuits all on the original fuse box.
Alloy light weight front pulley set.
Original ecu which is the one I use on this set-up
Alternator.
Original ignition key block with immobiliser still working.
Digital dash with all connections for fuel and temp, taco & speedometer,
Engine loom and standard ecu.
Flywheel and clutch.
Inlet and throttle body, erg removed.
Push button start.
Fog light swich and wires, auto turns of when lights are turned off.
Brake light switch.
Fan circuits, auto clicks on and off as required.
Loom: Parts removed from the original loom;
Abs sensor’s along with the wires and control unit.
Cold air pump along with the wires and fuse box.
Electric roof motor’s along with all the wires.
Audio loom.
Alarm.
All the wires connected to the door locks and mirrors.
Loads more work done on this loom.
Not to include coil packs, radiator, gearbox, exhaust, engine mountings, starter motor, wiper motor.
I’ve won my class (sport libre) at Wigan sprint & Barbon hill climb with this engine so it’s a good tried and tested low mileage motor.
Gearbox and Hondata Flashpro by separate agreement are available. These engines are a handful in a light car when they hit vtec so I had the flashpro and mapping fitted at a cost of around £900 which uses the standard ecu (included), but allows a re-map to tune to your requirements. You can set the rev limiter and launch control also with the flashpro. I have the limiter set to 9000 rpm which works well.
I think I’ve about covered everything, but just ask if anything is unclear.
£3300 no offers. Or £4000 to include gearbox and flashpro.
Collection only.
eBay Item
http://www.kittenkitcar.co.uk
The Knobs
posted on 29/10/14 at 11:37 PM Reply With Quote
What is the total height from lowest point on sump to highest point on engine please?
unijacko67
posted on 29/10/14 at 11:45 PM Reply With Quote
It's 636mm or 25" from lowest part of sump to the highest part of the rocker cover, hope that help's. Cheers
unijacko67
posted on 1/11/14 at 10:02 PM Reply With Quote
Dyno info.....
unijacko67
posted on 16/11/14 at 10:16 AM Reply With Quote
Honda s2000 Package
Bump, may take offers, Cheers
unijacko67
posted on 3/1/15 at 11:28 PM Reply With Quote
sold
