Author: Subject: 195 Mig Welder
Myke 2463
posted on 30/10/14 at 07:33 AM Reply With Quote
195 Mig Welder
Anybody used one of these Wolf Professional MIG 195 Welder ebay no 251360717133 £234.99
Thanks for any info, good or bad.
Be Lucky Mike.
r1_pete
posted on 30/10/14 at 07:47 AM Reply With Quote
It depends what you want it for, 40 amp minimum isn't very good, for sheet steel you need 30, preferably 25.
Plus there is a red disclaimer about power supply needing to be industrial, from a 13A supply you'll pop fuses above 160 amp output, which effectively means you're buying a 40 - 160 amp machine if its domestic use.
I would look at the Clarke or R Tech range, I've never used one but Wolf don't seem very well respected for welders....
posted on 30/10/14 at 08:52 AM Reply With Quote
No experience with Wolf, but can recommend the Clarke 151TE.
