Author: Subject: Bodgability - why?
simonrh
posted on 30/10/14 at 09:54 PM Reply With Quote
Bodgability - why?
Did you really not have a better solution? No terminals and no heat shrink?
Hooked straight on to the battery.
CosKev3
posted on 30/10/14 at 10:53 PM Reply With Quote
Nice
Scary what some people think is acceptable
jollygreengiant
posted on 30/10/14 at 11:22 PM Reply With Quote
even worse than that Brown wire is usually for earths (although some people use black).
blakep82
posted on 30/10/14 at 11:33 PM Reply With Quote
Mmm, I've noticed ford edis is wired brown for live, black for earth, led autolamps tail lights are brown for live, white for earth. In fact all their leds are white earth. Things like the round leds used for side repeaters are black live, white earth. Weird
________________________
owelly
posted on 31/10/14 at 01:52 AM Reply With Quote
I think you may have answered your own questions. If the culprit had no terminals and/or heat-shrink, then they did what they could to 'solve' the problem. I'm guessing they were stuck in the middle of the desert when they needed to carry out the bodge.......?
[Edited on 31/10/14 by owelly]
http://www.ppcmag.co.uk
r1_pete
posted on 31/10/14 at 07:37 AM Reply With Quote
Back to the old 'Lucas' standards, brown was the colour for un switched un fused live.
Pity I can't see the picture, Co, Proxies.....
posted on 31/10/14 at 08:09 AM Reply With Quote
Brown always used to be power, blue headlights, red side lights, green indicators, purple horn.
These days nothing is standard from manufacturer to manufacturer or even between different models.
Daddylonglegs
posted on 31/10/14 at 10:06 AM Reply With Quote
It seems that the battery +Ve is also very close to the carbs unless I'm mistaken!
Smoking Frog
posted on 31/10/14 at 10:53 AM Reply With Quote
Was expecting a horror story today. That's scary! Although a common sight in the old days, especially on the radio cassette feed.
simonrh
posted on 31/10/14 at 11:09 AM Reply With Quote
I think that is just the perspective on the camera, there is a fair old gap in there in reality.
posted on 31/10/14 at 04:21 PM Reply With Quote
In modern tintop just getting feed can be a problem I use the piggyback tap connectors you can get for blade and min-blade fuse boxes.
Chris_Xtreme
posted on 31/10/14 at 09:29 PM Reply With Quote
the quantum loom has brown for the un-switched un-fused feeds from the battery. both of mine have been the same.. tho there have always been proper fixings at the end!
