Author: Subject: Wanted!! Throttle Bodies With Adapter Plates For KLDE V6
KFC
posted on 15/11/14 at 07:06 PM Reply With Quote
Hi all,
I'm after a set of throttle bodies for a klde V6. Maybe an abandoned project for the conversion. I'd try Clairetoo but she doesn't contact me any more as I don't know why. Anyway, any thing will be concidered.
dave-69isit
posted on 15/11/14 at 08:27 PM Reply With Quote
boddies
drop her a message she is busy making subframes but will respond
Ugg10
posted on 15/11/14 at 08:41 PM Reply With Quote
.....and my sump :-)
Try both email and U2U on here, you may need to be a bit persistent.
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
KFC
posted on 15/11/14 at 10:00 PM Reply With Quote
I've sent countless emails and messages. I think she's ignoring me as I complained about the accuracy of the machining, but I was happy to sort it myself.
dave-69isit
posted on 16/11/14 at 04:04 PM Reply With Quote
plate
manifacturing fault not claires my adapter is spot on as is every other part she has made for me and mazda tolerances are crap compaired to claires
KFC
posted on 16/11/14 at 04:25 PM Reply With Quote
It was a one off, first time making one, it wasn't water or laser cut, it was jig sawed out then a router was used but that wasn't the problem. A bolt wouldn't go in my engine but would in her engine, the pilot input shaft bearing locked up solid after I shrunk fit it, I measured it after and found that there was .0075" interference. I've sorted it now and I was ok with it and explained to him that I would sort it, no hard feelings but obviously there was.
