Author: Subject: Clutch adjustment Zetec/MT75
cortez
posted on 17/11/14 at 09:25 PM Reply With Quote
Has anyone a recommended pedal height at bite for the clutch?
I've set all the pedal heights but the bite of the clutch was about 10/20mm from the floor. Once I adjust the clutch to the desired bite height, the pedal height increased to about 20mm above the others!
I'm sure this is a common issue with a cable clutch setup. I have no adjustment at the pedal end and was considering fitting one.
I'd be grateful for any advise..........................................Thanks.
turnipfarmer
posted on 18/11/14 at 02:59 PM Reply With Quote
u2u sent
JAMSTER
posted on 18/11/14 at 06:47 PM Reply With Quote
did you fit the taller release bearing
cortez
posted on 18/11/14 at 08:10 PM Reply With Quote
No, I have the GBS extended clutch arm pin.
