Free: Coil overs, mirrors, padded dash, grease guns. Cheap: exhaust noise reducers / decibel inserts, auto carpet
Clearing out my folks garage, might be of use to somebody:
1) 3 x Coilovers from my first Locost. The fourth was destroyed when i wrote the car off in 2002, these have been dry-stored in a layer of protective
grime. Two have spherical bearings, the other rubber bushes. 1.9" dia springs of unknown rate, open length is 300mm, pretty sure I can dig out
the peg spanners for the adjustable seats. Should clean up ok, but no guarentees etc, hence free:
[img]Avo
Coil overs by rob_j_hopkins, on Flickr[/img]
2) 2 x flat mirror glass for bullet type mirrors, 92mm diameter. £0
Flat
mirror glass for bullet mirrors by rob_j_hopkins, on Flickr
3) Original padded dash, has passed SVA and IVA when fitted to a Fury. Has assorted switches, a demister + screen vents. £0
Fury
Padded Dash 2 by rob_j_hopkins, on Flickr
4) Exhaust decibel inserts - 60mm. Seemed to make a good job on my k-series fury. £10?
Decibel
Inserts by rob_j_hopkins, on Flickr
5) Grease guns: Large and small, think they're pre-loaded with vintage grease. £0
Grease
guns by rob_j_hopkins, on Flickr
6) Auto carpet, 2 large black sheets at 190cm x 150cm, from Coverdale in Wigan. I'd guess its Blenheim black, got a bit carried away buying
pre-IVA. Covers all sorts and mysteriously falls out after IVA. £10 each, or both for £15.
All parts can be collected from Macclesfield or Runcorn.
[Edited on 23/11/14 by LancasterBob]
