Author: Subject: Repairing Fibreglass
neilp1
posted on 25/11/14 at 12:55 PM Reply With Quote
I'm going to have a bash at repairing some damage to my rear arch as shown in the photos. This was caused by some cock reversing into me whilst I was away from the car. Unfortunately for me the cock decided not to hang around!!
The crack does run behind the light.
Can anyone give me any good pointer/advice for this repair as I have limited experience on this.
[img] Description
[/img]
AndyW
posted on 25/11/14 at 03:14 PM Reply With Quote
Im sure someone will be along soon with a better answer from mine, but for now I would drill a small hole at the end of the crack, this will stop it spreading further
garyo
posted on 25/11/14 at 04:17 PM Reply With Quote
In my experience, stabilising the damage with good use of hole drilling, and strengthening the wound by laying up some GRP on the underside is fairly easy.
The difficult part is getting a pigment match, and then getting one that stays the same colour over time as the resin fully cures. I presume it gel coat and not sprayed? Can you get a pot of the gel from your manufacturer rather than mixing your own pigment in to while gel then that'll help enormously.
Gary
twybrow
posted on 25/11/14 at 09:31 PM Reply With Quote
Is it a painted surface, or is it gelcoat? Knowing this would help direct you to the right course of action.
spiderman
posted on 25/11/14 at 11:45 PM Reply With Quote
Gaffa tape.
I'll get my coat.
Spider
neilp1
posted on 26/11/14 at 05:43 AM Reply With Quote
Its gelcoat.
Mikef
posted on 26/11/14 at 08:28 AM Reply With Quote
You really need to get the manufacturer name, code and batch number if poss. Still not easy to get a good match and blend in. Lot easier to do if its painted.Personally if you want a really good job, I think I would go the professional route.
twybrow
posted on 1/12/14 at 11:11 PM Reply With Quote
Originally posted by neilp1
Its gelcoat.
So if it is gelcoat - have you managed to obtain some of the gelcoat? A lot of suppliers will keep samples for exactly this reason. Otherwise, ask the bodywork supplier to give you the name of the resin company who made the gelocat so that you can get some more of the right colour match (unless it is the same batch, it wont be 100%).
Firstly, stabliise what you have. I would start by drilling out the root of any cracks, and using a small burr grinder, form a V along any cracked edges (feather the edge) so that you have a clear path from back to front - you will work from the back side of the laminate. If needed, you can cut out whole areas and add back in new material as long as you can reference the shape from the surrounding surfaces.
Next, take something shiny and flexible enough to conform to the shape you want to repair - e.g. a thin sheet of alu, GFRP or similar. Apply mould release to the flexible plate, and then fix it to the gelcoat side of your laminate - bolt it, stick it - your choice (just make sure it wont come off until you want it to come off). Next, apply your gelcoat from the back side - you are aiming to apply a coat in 2 passes, so dont go on too thick. Then, when that is beginning to cure, layup your glass on the back of the gelcoat, starting inside the gaps/cracks and working outwards with increasingly large pieces, until your hole is filled.
Let it cure and then remove the panel, and fill/repair the holes you fixed th eplate with, and any dodgy edges where new material meets old. Once it is all filled and level, polish it with Farecla type products and stand back and admire your handy work....
