Author: Subject: Electric rad fans........
CosKev3
posted on 25/11/14 at 10:01 PM Reply With Quote
Is it worth the extra £££££££ to buy a Kenlowe or Spal over the budget slim line fans which are circa 1/3 cheaper?
The Black Flash
posted on 25/11/14 at 10:14 PM Reply With Quote
No direct experience, but I read enough horror stories about the cheap ones when I was looking for one to convince me that it was.
ashg
posted on 25/11/14 at 10:20 PM Reply With Quote
look at the cfm thats how you decide. if your rad is thicker than 45mm then you will need a beast of a fan to drag the air through.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
Ben_Copeland
posted on 25/11/14 at 10:43 PM Reply With Quote
The more expensive ones run much faster. You can hear the difference between the cheap ones and more expensive.
I run 2 x 8inch cheap fans and it's ok for an alloy radiator and inter cooler sandwiched together .... JUST
Ben
Locost Map on Google Maps
Enter Your Details Here
CosKev3
posted on 25/11/14 at 11:35 PM Reply With Quote
Ok cheers.
I found a Spal supplier in the USA selling them at a very good price, but the shipping killed off that idea.Worked out the same price as buying in the UK.
renetom
posted on 26/11/14 at 09:51 AM Reply With Quote
fan
We used a polo fan from ebay £6.00
Quiet powerful easy to fit, perfect with polo rad.
& its reversible.
SPYDER
posted on 26/11/14 at 09:52 AM Reply With Quote
We used two SPAL fans from an Aprilia RSV on our Phoenix Fireblade build. We paid a total of £18 for the pair on Ebay.
40inches
posted on 26/11/14 at 10:08 AM Reply With Quote
A few reasonably priced ones here, near bottom of page.
EBAY
CosKev3
posted on 1/12/14 at 09:50 PM Reply With Quote
I'll keep an eye on ebay, need a 9 or possibly 10 inch fan.
CosKev3
posted on 1/12/14 at 10:18 PM Reply With Quote
How do you find these fans manage the heat?
SPYDER
posted on 2/12/14 at 10:09 AM Reply With Quote
They're fine. They manage perfectly on superbikes, many of which only have one fan fitted.
Mounting them was tricky. My co-builder made a superb mounting plate.
If your radiator is correctly specced to suit your engine then they will only be needed when standing in traffic or just ticking over for ages.
chrisxr2
posted on 2/12/14 at 11:03 AM Reply With Quote
I believe the one on my old haynes roadster was also from a polo.
Life moves pretty fast, if you don't stop and look around once in a while, you could miss it.
CosKev3
posted on 4/12/14 at 09:17 PM Reply With Quote
Ok cheers
Keeping an eye on those Aprilia fans on E-Bay, like the look of them
