Author: Subject: L7 Cub Sport Seats
johnnybizzle1986
posted on 18/12/14 at 04:27 PM Reply With Quote
L7 Cub Sport Seats
Hi Guys,
At my IVA the examiner asked to see evidence of the make up of the steel frame of the seats, mainly between the harness cut outs. myself and he could feel steel there but he wanted to see a picture.
was wondering if anyone has a photo of the seats without the vinyl and padding on with the steel frame exposed?
regards Jon
adithorp
posted on 18/12/14 at 07:03 PM Reply With Quote
Whats the alignment of the belts through the seats holes?
If the belt slopes up from the top anchorage to the hole then the seat is regarded as structural and you may be asked for info about the seats strength. If the belt is horizontal or downhill from the anchorage to the hole the seat structure doesn't matter. Tthats what I was told at SVA when I asked why they were putting a spirit level on my belts.
http://jpsc.org.uk/forum/
johnnybizzle1986
posted on 18/12/14 at 07:19 PM Reply With Quote
The harness points are lower than cut outs. So i need evidence of what is holding the harnesses
up.
adithorp
posted on 18/12/14 at 08:48 PM Reply With Quote
Most people with that issue use longer bolts and spacers to raise the belt mounting point. It's a poor engineering solution as the bending force on the mount is high but it will pass IVA... and then you can remove the extensions.
