Author: Subject: Zx9 tuning
greavesy7
posted on 20/1/15 at 10:12 PM Reply With Quote
Zx9 tuning
What sort of mods are there for a zx9 engine and what sort of gains would you expect
Wadders
posted on 21/1/15 at 08:45 AM Reply With Quote
IMHO the only mod worth doing on such an old engine would be fitting a turbo which should give you about 200 bhp.....you can get a big bore kit and get head work done but it would be cheaper and easier to drop a ZX12 in or any of the modern 1000's........instant hp hike.
ZX9 was a great engine in its day, but old hat now, rather than tuning or swapping, losing weight can help it compete with newer engines.
Al.
dave_424
posted on 21/1/15 at 11:16 AM Reply With Quote
Converted mine to megasuqirt fuel injection, turbo from a volvo. Makes 225bhp at 15psi of boost with no problems, it is in an offroad vehicle though so not driven it much after the turbo compared to a road car.
See both my threads
Here at 7psi boost made 181bhp with a bad turbo manifold and other things http://www.locostbuilders.co.uk/viewthread.php?tid=184992
Here is at 15psi, better turbo manifold, all boost leaks fixed http://www.locostbuilders.co.uk/viewthread.php?tid=193224
200mph
posted on 21/1/15 at 04:15 PM Reply With Quote
See both my threads
Do you have an idea of your total spend on the conversion?
Mark
If it isn't broke, fix it until it is
dave_424
posted on 21/1/15 at 07:54 PM Reply With Quote
Just megasquirt or full turbo conversion?
If just the megasquirt, then
Megasquirt with loom - £300
Z1000 crank wheel - £10
ZX10 throttle bodies and injectors - £60
Injection fuel pump - £30
Fuel pressure regulator - £60
Thats pretty much it, unless I'm forgetting something
For the turbo its that plus
I Tig welded the exhaust manifold - £80
Turbo - £60
I used an external wastegate - £70
those are the main things, other misc things like hoses, boost pipes, intercooler (free), plenum (rover v8) etc - £100
I'm sure there are some other things that I have overlooked that bumps up the price a bit but those are the main things. I would say it could be easily done for under £800-1000
200mph
posted on 21/1/15 at 08:10 PM Reply With Quote
Very interesting, thanks!
dave_424
posted on 21/1/15 at 08:59 PM Reply With Quote
I did get a set of forged pistons for £50 and a cylinder spacer because I wanted a reliable strong engine for 15 psi, but I ran 7 psi on an unopened engine. I expect you could easy run 8-10psi on a stock engine just spacer and get 200bhp. When I removed the stock pistons and they looked great with no destination marks or anything
greavesy7
posted on 21/1/15 at 09:03 PM Reply With Quote
It's a 2003 engine so I wouldn't say it was that old. What sort of power do you get from standard with a 4 branch and a performance air filter ?
40inches
posted on 21/1/15 at 09:24 PM Reply With Quote
I think it unlikely that you would get any power increase from changing from the standard "F" exhaust and air box, there may even be a power loss http://www.locostbuilders.co.uk/viewthread.php?tid=186736
A rolling road session, done by a tuner who knows bike carbs, would be the most cost effective way to maximise power output.
ZX10R throttle bodies/injectors fit without modification, and give a healthy increase across the rev range, but will need the 10R ECU or a Megasquirt .
I think it would be better to get it set up and use it for a summer first, you may be pleasantly surprised
greavesy7
posted on 21/1/15 at 09:41 PM Reply With Quote
I've not driven it yet so I'm sure I will I just like researching !
Dave is there a reason why you kept to the standard air box over a pipercross sausage filter ?
40inches
posted on 21/1/15 at 09:46 PM Reply With Quote
I asked the question myself here; http://www.locostbuilders.co.uk/viewthread.php?tid=186736 So, based on the replies, I kept it
greavesy7
posted on 21/1/15 at 09:47 PM Reply With Quote
Smeak peak
greavesy7
posted on 21/1/15 at 09:50 PM Reply With Quote
greavesy7
posted on 21/1/15 at 09:52 PM Reply With Quote
40inches
posted on 21/1/15 at 09:53 PM Reply With Quote
Looking good, does it run OK?
greavesy7
posted on 21/1/15 at 10:00 PM Reply With Quote
[IMG]http://i53.photob ucket.com/albums/g52/Greavesy7/Mobile%20Uploads/th_trim.4C0CCDC4-2FE3-49C5-B99F-5B915CD71C3B_zpsuowye5wd.mp4[/IMG]
What do you think
