New Topic New Reply
Author: Subject: Transmission tunnel bottom
MadMaxx
posted on 25/1/15 at 03:46 PM Reply With Quote
It seems that a detachable alu pannel on the bottom of the transmission tunnel is quite uncommon despite a teorethical gain on drag force and a cleaner area. Is there any reason?
The only one seen is on Adithorp's car.
The same on engine bay. Am I wrongh?
posted on 25/1/15 at 03:50 PM Reply With Quote
A panel right across helps strengthen the floor. No need for a removal panel is there?
rdodger
posted on 25/1/15 at 04:14 PM Reply With Quote
I have one piece floor and removable tunnel top.
If I did it again I would make removable panels in the tunnel sides to aid access to the diff bolts. I think Caterham have this?
Andybarbet
posted on 25/1/15 at 04:24 PM Reply With Quote
My Luego chassis has welded in steel floor under driver & passenger, is it worth me making a panel to fit underneath to close in the tunnel ?
Dopdog
posted on 25/1/15 at 06:32 PM Reply With Quote
on my fury I have fixed floor under the seat and then all of the other panels unbolt. I have the engine bay and tunnel filled in as well
paulc
posted on 9/2/15 at 08:45 PM Reply With Quote
Been thinking about this for mine. Access looks tight once the panels are on.
40inches
posted on 10/2/15 at 08:53 AM Reply With Quote
Removable side panels are a must. In my opinion
Prop Catcher
Prop Catcher
New Topic New Reply
