Author: Subject: DIY scratch build efi manfold
kango
posted on 25/1/15 at 05:15 PM Reply With Quote
I need to do it because I changed the angle of my carb fed engine and Webers are getting scarser and scarser. I also prefer using newer technology.
Who has done it and what help can they offer to make the fabricatin a little less painfull
r1_pete
posted on 25/1/15 at 05:21 PM Reply With Quote
have a look in my photos folder project e type efi...
assuming you're on DCOEs have you thought about Jenveys.
kango
posted on 25/1/15 at 05:33 PM Reply With Quote
I stay in SA
mark chandler
posted on 26/1/15 at 08:54 AM Reply With Quote
Pop down to your local super ike breakers and get some throttle bodies off a 600cc 4 cylinder bike, then make a manifold to suit so either get a length of 3/8th - 1/2" ali and carve a new inlet plate or take a saw to your existing manifold and cut off the pipes.
You now need to weld some stub tubes to match the throttle body spacing.
If you do not have access to a Ali welding gear then make a new manifold out of steel.
The bike throttle bodies will come with injectors, TPS and MAP sensors, you will then need to add an ECU, megasquirt works well for a budget.
Andybarbet
posted on 26/1/15 at 09:00 AM Reply With Quote
Here's mine
Airbox back plate made
davidimurray
posted on 26/1/15 at 10:07 AM Reply With Quote
Some details of mine on my thread here - http://www.locostbuilders.co.uk/viewthread.php?tid=192871
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
kango
posted on 26/1/15 at 05:56 PM Reply With Quote
I am more leaning towards a plenum design.
A lot easier to set up and i have a supercharger lying on the rack as a future project
kango
posted on 27/1/15 at 04:39 PM Reply With Quote
How do you balance the individual throttle bodies .
Saw a very expensive balance guage. Can not even find one in SA
ed1801
posted on 27/1/15 at 04:52 PM Reply With Quote
I swapped my weber 45s on a DCOE manifold for a pair of twin jenvey TBs as a bolt up and go conversion. Surely easier than building a new manifold.
The sale of the webers paid for the (2nd hand) jenveys. I used a bike carb balancer for set up which was 57 quid http://www.carbtune.co.uk/carbpric.html
The jenveys had a tps, injector rail and injectors on them already. Maybe i was just lucky!
kango
posted on 28/1/15 at 05:08 AM Reply With Quote
Problem is my current manifold is for a single solex downdraft, and for an OEM installation of the engine 10 deg off vertical.
I have moved the engine to vertical.
Can not machine the face of the manifold to vertical, because all thebolt holes are 90 deg to the face.
Would like to install a supercharger at a later stage
