Author: Subject: For Sale- Clear out - including bike engine
dan_g8
posted on 25/2/15 at 02:16 PM Reply With Quote
Im having a clear out and currently have the following forsale: all items are posted only p&p is included in price.payment via paypal
2x pairs of sierra front hubs £45 (Both sold pending payment)
1x pair sierra front calipers £45
1x sierra steering column inc switches £45
1x sierra 7.5 open diff, bolt on drive shafts, hubs £90 (sold pending payment)
1x pair of rear calipers for vented brakes £45
1x sierra prop shaft £35
1x 1.6 mx5 engine £100
1x pair mx5 front uprights £45
1x mx5 open diff with drive shafts & uprights £90
1x mx5 propshaft £35
1x pair of ali offset haynes roadster mushroom adapters £35
1x full set of poly bush's in grey in stainless steel crush tubes £45 (sold pending payment)
1 x full set of 33.7 wishbone tubes £35
1x pair threaded front upper wishbone tubes - sierra £15
1x pair threaded front upper wishbone tubes - mx5 £15
2x haynes roadster chassis plate kit (ill need to double check nothing is missing) £45 (1 sold pending payment)
1x zzr1100 donor package, engine, clocks, exhaust manifold, loom, carbs - should be nearly everything to make it run - good runner when removed. £550
1x prop adapter zzr1100 to ford prop £55
1 x Haynes roadster nose second £75
1 x haynes roadster scuttle second £75
1x haynes roadster rear tub second £75
1x pair haynes roadster front lower wishbone plates £15
1x sierra master cylinder £25
im sure there are more items that ill discover over the next few days.
[Edited on 26/2/15 by dan_g8]
posted on 25/2/15 at 02:29 PM Reply With Quote
What vintage are the mx5 bits? Mk1 or 2. All off the same car?
dan_g8
posted on 25/2/15 at 02:48 PM Reply With Quote
not 100 % sure of the vintage, ill post some pics up tomorrow and i believe they are all from the same car.
richwill
posted on 25/2/15 at 04:17 PM Reply With Quote
I would like a chassis plate set please.
spiderman
posted on 25/2/15 at 05:11 PM Reply With Quote
Hi'
I'd be interested in the Sierra diff,driveshafts and uprights. Do they have the hubs with them?
If you have some pictures and they're what I want I'll have them.
Spider
Angel Acevedo
posted on 25/2/15 at 05:19 PM Reply With Quote
First dibs on Bushes and Crush Tubes.
Thanks.
AA
gavin174
posted on 25/2/15 at 06:55 PM Reply With Quote
Dan
interested in sierra front hubs if they are still available...
cheers Gavin
Edwardo
posted on 28/2/15 at 12:06 PM Reply With Quote
U2U sent regarding Roadster rear tub.
Tony
dan_g8
posted on 2/3/15 at 09:13 AM Reply With Quote
Parts currently still available are as follows:
spiderman
posted on 5/3/15 at 10:38 AM Reply With Quote
Hi Dan,
can you let me know when you have posted my items and send me the tracking number? I can keep an eye on where they are and make sure I'm not too far away once it get's close to me.
Cheers.
Spider
spiderman
posted on 8/3/15 at 08:39 AM Reply With Quote
U2U sent.
Spider
spiderman
posted on 8/3/15 at 11:26 AM Reply With Quote
I might be interested in the Sierra propshaft if it's still available
cheers
Spider.
Spider
spiderman
posted on 8/3/15 at 09:39 PM Reply With Quote
Hi Dan,
Let me know when you can send the parts. No rush as I can wait
cheers
Spider.
[Edited on 9/3/15 by spiderman]
Spider
dan_g8
posted on 9/3/15 at 09:29 AM Reply With Quote
Spider- you have u2u
spiderman
posted on 1/4/15 at 10:45 PM Reply With Quote
Hi Dan,
received my parts yesterday, seems as though the courier took them around the country on a touring holiday. Very very pleased with my purchase.
All the very best to you and a pleasure to do business with you
Spider.
Spider
gavin174
posted on 1/6/15 at 06:51 PM Reply With Quote
Dan
can you check your u2u's please
Gear Monkey
posted on 27/7/15 at 12:04 PM Reply With Quote
Hi Dan,
Are those the MX5 parts you had from me??
Can you check your U2U messages please
Paul
Neilwilson
posted on 27/7/15 at 12:28 PM Reply With Quote
u2u for nose cone and scuttle
