Author: Subject: Estimating Clutch Release Force?
cloudy
posted on 26/2/15 at 10:14 PM Reply With Quote
I'm trying to analyze stress on a bike clutch slave mounting plate, and want to estimate the likely force required to release a GSXR 1000 clutch pack - the actuation is direct with no leverage. Any good ideas? I can't find any information on the rating of the springs, let along the preload
Any help welcome!
Thanks,
James
www.warnercars.com
bi22le
posted on 26/2/15 at 11:04 PM Reply With Quote
But some weighing scales from a fishing shop and give the lever a tug? !?
Please read my ring story:
cloudy
posted on 26/2/15 at 11:50 PM Reply With Quote
It's hydraulic via a push rod - doubt I could do it by hand! Not got the hydraulics piped up so can't test for pedal effort and then work out the ratio
www.warnercars.com
cosmick
posted on 28/2/15 at 09:48 AM Reply With Quote
What model of GSX R1000 is it and are you trying to make a cable clutch instead of hydraulic?
If it can't be fixed with a hammer then its probably an electrical problem.
cloudy
posted on 28/2/15 at 02:39 PM Reply With Quote
K1/2 - converting cable to hydraulic
www.warnercars.com
cosmick
posted on 28/2/15 at 11:13 PM Reply With Quote
I think you will find that a K7/8 Sprocket cover will fit your engine and it uses a Hydraulic cylinder. It will save you a lot of work and calculation. Are you fitting a prop shaft. If so you could probably cut the area to accommodate.
