Author: Subject: Duratec Flywheel lock
peter030371
posted on 10/3/15 at 05:47 PM Reply With Quote
Anyone got any good pictures of a simply, home made, tool for locking the flywheel on a duratec?
Tried my impact gun and the flywheel bolts won't budge so time to get the break-bar on it and errr brake something!
Badger_McLetcher
posted on 10/3/15 at 05:55 PM Reply With Quote
Not sure about the duratec specifically but in the past I've used a bit of thin metal with two holes successfully - one hole gets bolted to the flywheel, the other to the engine. You do have to be careful not to bend or damage anything though
If disfunction is a function, then I must be some kind of genius.
davidimurray
posted on 10/3/15 at 08:24 PM Reply With Quote
My homemade setup
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
dave r
posted on 10/3/15 at 08:51 PM Reply With Quote
seen one somewhere, that uses the 2 bolt holes for the startermotor, and locks into 1 tooth of the flywheel
I'd love to give my imaginary friend a great big hug,
but this jacket makes it impossible.
big-vee-twin
posted on 11/3/15 at 08:33 AM Reply With Quote
I did the same as Davidmurray but held it on one tooth.
http://www.triangleltd.com
keithjardine
posted on 11/3/15 at 11:50 AM Reply With Quote
My state of the art flywheel locking tool on an old zetec......
Angel Acevedo
posted on 11/3/15 at 03:52 PM Reply With Quote
And Locost...
I LIKE IT....
AA
peter030371
posted on 11/3/15 at 05:03 PM Reply With Quote
Thanks all, some good ideas but keithjardine that is close to genius and I will give it a try tomorrow
rodgling
posted on 11/3/15 at 05:06 PM Reply With Quote
That may be close to genius but it doesn't use the awesome power of two hammers:
believe it or not this worked perfectly...
se7ensport
posted on 13/3/15 at 11:12 PM Reply With Quote
one hammer... flywheel swap
flywheel swap
dave r
posted on 14/3/15 at 08:10 AM Reply With Quote
made one for myself today, had to lock the engine whilst in the car (needed bottom pulley undone)
the 2 holes pick up the starter motor blots and the box section engages on the ring gear
