Author: Subject: Initial brake fill and bleeding
johnH20
posted on 10/3/15 at 08:20 PM Reply With Quote
I know from experience this can be a PITA. If I had access to an air line I would do a vac fill but I don't. So I am after best hints and tips. My basic plan is to first flush the system up to the callipers to ensure their is no residual debris in the lines using what ever cheapo fluid then make final hose attachment and start with 'proper' high spec fluid ( car is destined for track days ). This will be by the traditional two man method. Previous experience suggests that this will not be a continuous process but requires some relax time to get the last air bubbles to release.
Given that high spec fluid is expensive I would rather not throw the second pass away but recycle it after any air bubbles are released. Obviously this fluid needs to kept clean and to the extent possible protected from moisture. Is this a no no? Really not looking forward to this so any help would be much appreciated.
PSpirine
posted on 10/3/15 at 08:34 PM Reply With Quote
I've got a handheld vac kit which you're welcome to borrow (although notice you're somewhat far away!), however, having used a number of different systems to completely flush/bleed some cars, I'd do it using a pressure bleed (the spare tyre kit thing you can buy in halfords for a tenner).
Least effort, and in my personal experience, the most effective.
The way it's done at work on new cars is:
- system assembled dry
- vac pull on master reservoir
- while under vacuum, brake fluid filled into reservoir
- vac pulled 2nd time to remove any air bubbles
A bit impractical unless you've got the kit which is the size of a room!
[Edited on 10/3/15 by PSpirine]
Jon Ison
posted on 10/3/15 at 08:35 PM Reply With Quote
From my own experience a brake system holds a surprisingly small amount of fluid when full.
I do my first fill/flush like you suggest then connect to the callipers and so far been realy lucky such that they have bled themselves by simply leaving the nipples out until I was satisfied that all the air was purged, I bleed that way at a total loss, they hold that little fluid it's not in my opinion worth the risk of saving it.
luke2152
posted on 10/3/15 at 08:46 PM Reply With Quote
Those one man brake bleed tools work a charm and cost about £3 (it is just a ball bearing in a tube after all) and make the job so much easier.
I'd start on one corner, work my way around and then do each corner a 2nd time to make sure you get the last of the air out. You'll probably do all that with 500mL so wouldn't bother with the cheap stuff.
baz-R
posted on 10/3/15 at 09:07 PM Reply With Quote
i have never had any issues with priming brake fluid systems and only use a basic clear pipe
a little trick i do is simply let gravity do the hard work for you and never have a system where the fluid res is lower than anything else
brake grease the nipple threads to save suck back later on and all pistons all the way home, fill the system, open all nipples (do not pump pedal!) and go make a brew
when the nipples start to drip close them one by one and when all have let a few drips out attach a clear pipe on shortest line and open nipple again watch gravity feed fluid for aroud 30secs and bubbles should be gone in line and close nipple , do each corner in turn working from shortest to longest lines
now press pedal with all nipples closed and it shoud be hard
the key is to alow the fluid to naturaly drain in and push the air out. as pumping or vacum can mix in air bubbles.
i can usualy only waste 100ml fluid on a dry fill system
as for fluids unless your useing silicone base types just use a quality dot 5.1 fluid that has been sat still in a sealed container its not expensive
[Edited on 10/3/15 by baz-R]
JAG
posted on 11/3/15 at 10:51 AM Reply With Quote
it's not expensive
It kinda depends how serious you are about trackdays and brake fluid... have a look at Castrol SRF Brake Fluid
HERE
It has a very high dry boiling point - 325 Celsius and costs between £42-50 per litre.
Justin
johnH20
posted on 11/3/15 at 11:39 AM Reply With Quote
Thanks for these tips - very useful. My difficulty in the past is probably due to having floor mounted pedals/master cylinders so I could not use the gravity method. That's what I will try now that I have a top mounted pedal set up.
baz-R
posted on 11/3/15 at 12:36 PM Reply With Quote
Originally posted by JAG
it's not expensive
HERE
yes but there are identical products in the market at around half the cost of that
also a std dot5.1 dry boils at 260c and dot4 230c
JAG
posted on 11/3/15 at 02:32 PM Reply With Quote
Not True - there is no other product that dry boils at 320 Celsius
You can read all about it - Product Data Sheet
[Edited on 11/3/15 by JAG]
Justin
threadbare wallet
posted on 14/3/15 at 06:43 AM Reply With Quote
Dot 5 absorbs water so easy dont you have to change virtually monthly? Some 5,1's are better but the above is one of the best i have yet found.
Very few things are "really" needed.
posted on 14/3/15 at 07:53 AM Reply With Quote
Avoid special brake fluids like then plague, racing brake fluids are highly hygroscopic, it is the water contamination in brake fluid that will cause long pedal.
Normal DOT5 .1 or even DOT4 fluids changed yearly are more than adequate fade of the friction material will occur before the fluid boils.
[Edited on 14/3/15 by britishtrident]
posted on 14/3/15 at 07:58 AM Reply With Quote
DOT5 Silicone fluid has it own problems in that you can get a pocket of water trapped in the system.
Normal DOT5.1 is all that is required.
posted on 14/3/15 at 08:01 AM Reply With Quote
Never ! put mineral grease anywhere near brake hydraulics.
posted on 14/3/15 at 08:07 AM Reply With Quote
DOT5 fluid is not hygroscopic, it repels water.
Because isolated pockets of moisture can occur in the system DOT 5 fluid is only really suitable for classic cars which stored by collectors for years without moving.
v8kid
posted on 14/3/15 at 08:54 AM Reply With Quote
I think you mean silicon not DOT5?
You'd be surprised how quickly the sales people at B&Q try and assist you after ignoring you for the past 15 minutes when you try and start a chainsaw
posted on 14/3/15 at 11:51 AM Reply With Quote
No I think perhaps you are con confusing DOT5.1 with DOT5
SAE DOT 5.1 is the conventional polyester glycol fluid
SAE DOT 5 is Silicone based
DOT 5 was developed to meet a US/NATO specification that was aimed at vehicles in long term storage.
See Wikipedia DoT5
DOT 5.1 predates DoT5.0 by a few years the minimum boiling point specification is the same and DOT 5.1 can be used to top up systems which previously bee filled with DoT4 or even Dot3
ee Wikipedia DoT5.1
bigfoot4616
posted on 14/3/15 at 06:13 PM Reply With Quote
on cars like most on here yes i agree, but when i used to track an integra i had to use something like the castrol linked above, may even have been that one, so i didn't cook the fluid.
threadbare wallet
posted on 15/3/15 at 07:09 AM Reply With Quote
....i knew it was a pain in the arse in some way lol thanks for the info chaps,always good to learn more.
baz-R
posted on 15/3/15 at 07:33 AM Reply With Quote
That is why I put brake grease? The red brake grease was designed to be used inside the brake hydraulics and is what you will find used to lubricate rubber pistons seals so I can see no reason why it can't be used to seal nipple threads?
