Author: Subject: Producing body in cad from paper drawing
CC Cyclone
posted on 15/3/15 at 07:18 PM Reply With Quote
Hello All,
I'm tackling a new project, have the chassis built and now need to make a buck. The plan was to go down the plywood egg crate with foam infill and then take moulds from the buck.
Now the car in question is an historic racer / replica that isn't in production and although I could hand form the shape over a very long period of time, I am looking into cutting plywood sections every few hundred millimetres from a cad drawing. Now here is the bit I need help with: I have a JPEG image that shows a 3d wire frame in three quarter view of the car in question, unfortunately I don't have a cad file and am really unlikely to get my hands on one. My question therefore is this - is there any way if taking the 3/4 view, perhaps drawing over it in cad to create a 3d model which I could then use to cut my cross sections through, or do these things usually get generated from 2d elevations of front / side / rear etc? The only drawing I can find is the 3/4 view after months of searching and I don't know enough about 3d modelling. I do have wheelbase etc dimensions which would in theory make it scale able?
So, good people of locostbuilders, does anyone know if what I am hoping to achieve is possible? If so any pointers as to who I may be able to approach for a quote?
JC
posted on 15/3/15 at 07:25 PM Reply With Quote
Draw the sections on paper, enlarge to full size using an overhead projector. Cut these from polystyrene and mount to chassis. Add filler, sand, sand and sand, then mould! There's a thread on here somewhere describing it in detail....
CC Cyclone
posted on 15/3/15 at 07:44 PM Reply With Quote
Thanks, that sounds like a plan, although I was thinking the ply might make it a bit more stable?
Still need to generate the sections from the drawing using this route and so my original problem still stands, I think.
liam.mccaffrey
posted on 15/3/15 at 07:46 PM Reply With Quote
just as a matter of interest what is the car?
Are you able to post the pics that you have? It might give people a better impression.
When I was considering this I was lucky enough to find a front and side elevation of the Talbot lago T26C. I never followed through with the project, but I may do in the future.
Build Blog
Build Photo Album
Sam_68
posted on 15/3/15 at 07:49 PM Reply With Quote
Yes, it's possible.
I don't know of any software that will do it directly (doubtless it exists somewhere, but it will be very specialised).
But long, long ago - before 3D CAD was invented - we used to draw perspectives manually, by setting up the plan on a drawing board and projecting dimensions up from focal point and vanishing points. You can use this technique manually on CAD to 'reverse engineer' 2D section profiles from an image of a 3D wireframe.
How good the result will be depends on the resolution of your JPEG. You will need a very high resolution image and enough straight lines or known points to project the vanishing points for it to be really worthwhile.
And it is a very tedious job, requiring someone who understands perspective, not just trained to push buttons on a CAD workstation (though they'll need to know how to do that too).
I'm not even going to offer, 'cos I'm far too busy to take it on, but assuming your JPEG is of adequate quality to make the result worthwhile, I'd suggest that you're looking at £several thousand at anything like commercial rates.
Others may be able to suggest a cheaper/quicker solution, if they know of, or have access to appropriate software.
designer
posted on 15/3/15 at 07:56 PM Reply With Quote
You will get better answers if you name the car! Is it that secret.
Somebody, somewhere, might have the drawing you want!
CC Cyclone
posted on 15/3/15 at 08:03 PM Reply With Quote
Can post the image I have tomorrow, it was a one off special / prototype.
Fred W B
posted on 16/3/15 at 11:14 AM Reply With Quote
See story here
CANAMSA body
My opinion, getting it to look right, just from a single drawing will not be easy. If you need to pay someone to do it it will be expensive, if it can be done at all.
Fred W B
[Edited on 16/3/15 by Fred W B]
Mistron
posted on 16/3/15 at 06:29 PM Reply With Quote
Cad? Who needs CAD?
Here's 3 of my projects
a previous project: http://myweb.tiscali.co.uk/racecar/pandora/body.htm
and my current one: https://www.flickr.com/photos/44645707@N00/sets/72157632087827009/
and one I helped with for a Porsche collector (It's a long thread, but here is a link to some pictures of an early itteration. we then went on to make a 1/5scale model as it wasn't quite what he's wanted afterall....) : http://www.ddk-online.com/phpBB2/viewtopic.php?f=3&t=28047&start=930
However long you think it will take, that will get you started. But it's a lot of fun, very satisfying, can be boring, itchy, dusty and rewarding.
Go for it!
and if you need advice, feel free to ask
Al
[Edited on 16/3/15 by Mistron]
CC Cyclone
posted on 17/3/15 at 08:41 AM Reply With Quote
Al,
I'm a big fan, I have to confess I'm a ddk member moonlighting on the LocostBuilders Forum. My project has a hint of Porsche content....
Thanks for the input guys, I have realised that actually as I have a rolling chassis I can go about this the old fashioned way with 2d paper and card templates to flush out the shape. Will keep you posted.
Mistron
posted on 17/3/15 at 07:56 PM Reply With Quote
haha, am I being stalked? or is it just that in the massiveness of the internet, the loonies always end up bumping into each other.
Needless to say, if you need any help / advice, just drop me a line and I'll help if I can
Al
