Author: Subject: Overfueling
zetec-phill
posted on 24/3/15 at 06:24 PM Reply With Quote
Overfueling
Zetec 2 lt blacktop running on ford ecu..( BASH) intermitent rough running..
all sensors are new that came with new engine..
put diagnostics on comes up with fuel system overload.. code po 172
a comes up with code po443 thats the evac thing..
any ideas
posted on 24/3/15 at 07:52 PM Reply With Quote
You need to access OBD II live data as a first step, this will give you an idea if the sensors that affect fueling are giving sensible readings.
However a P 0443 indicates a problem with purge valve control circuit, as a test try disconnecting the purge pipework from the the manifold and capping it off.
DW100
posted on 25/3/15 at 10:25 AM Reply With Quote
P0172 Is Fuel system too rich (bank1)
Need to check things like fuel pressure, map sensor, airmass meter, throttle position sensor etc.
If it is non standard, check that the injectors aren't too big or leaking etc.
zetec-phill
posted on 27/3/15 at 05:16 PM Reply With Quote
OBD readings
FIRST START CAR STATIC THIS REFERS TO THE ABOVE QUESTION CAN ANYONE THROW SOME LIGHT ON THESE
ROUGH RUNNING FIGURES ???????
THAT WAS YESTERDAY
CODE PO172 WENT OUT TODAY DID 40 MILE OK
LET CAR STAND 1 HOUR TOOK OUT AGAIN RUNNING A BIT ROUGH,, ON ACCELERATION
AROUND 2000 REVS HESITATION A MISSING..???
LOAD PCT% 25.1
ETC 75
SHRFT 1 -- 1.6
LONG FT 1 0.0
RPM 1054
_____________________
TOOK OFF 02 SENSOR
BETTER RUNNING
CODE PO172
LOAD PCT% 64.3
ETC 75
SHRFT 18 .8
LONG FT 30.5
RPM 836
______________________
REPLACED 02
DID 20 MILE DRIVE
RUNN ING OK ??
NO CODE SHOWING
LOAD% 22.0
ETC 97
SHRTF 1 -- 11.7%
LONG FT1 12.5%
REVS 1068
posted on 27/3/15 at 06:21 PM Reply With Quote
Something far wrong with a LTFT 10% or more. A 10% LTFT won't general trigger a fueling code but the emission monitor tests fail will on the cat effectiveness.
Sounds like a vacuum leak which could point to the evap control valve.
[Edited on 27/3/15 by britishtrident]
zetec-phill
posted on 27/3/15 at 07:41 PM Reply With Quote
not running evap valve as far as i know
plenum chamber standard throttle body a maf,,,and idle control valve
