Author: Subject: Repairing broken teeth on a gear cog?.
Jenko
posted on 30/3/15 at 10:10 AM Reply With Quote
While trying to undo a nut on a very old (1926) BAS motor bike, one of the teeth broke on the cam lobe gear. It a complex little bit of machining as the cam lobe and the gear are machined from the same piece of material. Being 1926 and very rare a now one is not on the cards.....So, does anyone know of a specialist company who can repar these sort of things?.
Thanks.
MY BLOG - http://westfieldv8.blogspot.co.uk/
posted on 30/3/15 at 10:46 AM Reply With Quote
Any decent engineering machine shop should be able to repair that. They'll probably mill out the entire tooth and a fair depth into the gear itself, then braze a suitably machined lump of cast iron in and then re-cut the tooth.
A look through the Yellow pages and some time on the phone should find someone reasonably local.
The Black Flash
posted on 30/3/15 at 12:15 PM Reply With Quote
I was looking recently to get a lathe gear repaired, and couldn't find anyone who advertises gear repairs specifically. So looks like you'll have to ring around...
cryoman1965
posted on 30/3/15 at 03:21 PM Reply With Quote
http://saundersmotorworks.com/
Try these guys.
N
Jenko
posted on 30/3/15 at 03:43 PM Reply With Quote
Thanks Gents...and thanks for the lead...quite local too.
