Author: Subject: ECU
zetec-phill
posted on 1/4/15 at 05:21 AM Reply With Quote
ECU
Im running a bash ecu at the moment on 2lt blacktop
it may have a fault in it...
so as anyone got an ecu a chip i can borrow... or buy..???
tims31
posted on 1/4/15 at 03:38 PM Reply With Quote
Phil,
Have you tried reading the fault with an OBD reader, did you install the reader plug when you installed the ECU loom?
It may help you narrow down the fault. the only problem with changing the ecu is you will also have to change the PATS ring and use the correct key with the matched ECU, unless you have managed to bypass all of these things???
Build: http://www.martinsfurybuild.co.uk/
