Author: Subject: Garrage clear out.
big_wasa
posted on 16/5/15 at 02:44 PM Reply With Quote
Garrage clear out.
Time to make some space for the other projects I have on the go. Ive now tipped over the diff three times
In two half's
A partial donor for an mx5 based Haynes Roadster or a Midlana.
Mx5 mk2 1.6 non abs front hubs / uprights.
Mx5 mk2 1.6 non abs rear hubs / uprights.
Mx5 mk2 1.6 4.1:1 diff.
Mx5 mk2 1.6 power steering rack. No good for a roadster but ideal for a Midlana.
All from the same donor why bust your nuts trying to get these of a full donor
mx5 mk1 xx upper steering column. (no switch gear)
Come and take it away from Spalding. £65, that's a tenner per hub, tenner for a diff / column and a fiver for a rack
Second half is the some bits for a rwd zetec turbo bench engine. I've decided to keep it fwd for the Midlana.
Ford sierra 1.6 cvh type 9 bell housing, starter motor, rwd flywheel and clutch. To fit a zetec the bolts need opening up, google it.
I doubt its lighter than a zetec Fly but it is deeper so you have a standard rwd clutch.
Come and pick it up from Spalding Lincs for £30 and sorry I am not splitting the starter motor.
The flywheel is ultra rare, an ebay breaker has one at £82 eBay Item
I haven't got any photos but I will get you some if wanted. cheers ........
posted on 16/5/15 at 04:07 PM Reply With Quote
Tut.. Too late!!
big_wasa
posted on 22/5/15 at 08:27 PM Reply With Quote
Only bump
Mr C
posted on 27/5/15 at 08:20 PM Reply With Quote
Warren, happy to give you a tenner a hub £40 in total, I could do with some nice clean ones especially since I broke one of mine in a press trying to get the shaft out.
The only problem is I'm miles from you in Kent, do you head south at all in your travels? or any other ideas?
Mike
Girl walks into a bar and asks for a double entendre, so the barman gave her one
