Author: Subject: Brake Bias Clevises to tight.
Irony
posted on 26/5/15 at 10:54 AM Reply With Quote
I think my brake bias clevises are nipped up to tight against the brake pedal to allow for proper bias adjustment. However as the pedal box is fitted it is a PITA to get to. A friend has suggested I need to unscrew the push rods from the clevises, spin the clevises around a couple of times and screw the push rods back in. I have tried this but I think the rubber boot on the push rod is gripping the push rod so tight I am turning the boot as well. This means when I let go of the push rod it spins back into its original position and the boot is rubbery. I am plainly avoiding taking the pedal box out as it is a nightmare getting to the swine. Anyone got any ideas?
rodgling
posted on 26/5/15 at 11:10 AM Reply With Quote
Yup, this is a right pain, fortunately there is an easy solution. Peel back the boot slightly, spray with silicone lubricant. The boot will then spin freely and you can easily turn the pushrod.
adithorp
posted on 26/5/15 at 12:27 PM Reply With Quote
+1
Only issue is if the boot has a crimped clip holding it to the shaft. You can just remove it and leave off; the boot is only a dust cover and it makes very little difference if the clip is missing.
Be sure it's silicone lube NOT mineral oil to lubricate the boot.
http://jpsc.org.uk/forum/
Irony
posted on 26/5/15 at 02:45 PM Reply With Quote
Originally posted by adithorp
+1
I have a crimped clip, it must be crimped flipping tight. Okay, I'll snip the crimps off and lubricate and try again. Cheers fellas
rodgling
posted on 26/5/15 at 03:02 PM Reply With Quote
No need to remove crimps, just grip the (lubricated) rubber boot (by hand) and turn in order to turn the pushrod.
Angel Acevedo
posted on 26/5/15 at 07:02 PM Reply With Quote
Crimp may be removed and if your picky, you may install a ty rap (Cable tie) when done.
I haven´t installed my pedalbox, but came to the conclusion that I will need to do so at some point in time.
HTH.
Irony
posted on 26/5/15 at 09:59 PM Reply With Quote
Hey up,
Problem solved! Thanks a bunch.
Angel Acevedo
posted on 26/5/15 at 10:16 PM Reply With Quote
Hey up,
Good to Know.
Then it is easier for me in the not so distant future...
Thanks Rodgling.
AA
