Author: Subject: St150 engine
Sschipps
posted on 5/6/15 at 05:41 PM Reply With Quote
St150 engine
Hi all, currently have 2.0 pinto in my tiger cat.. Found a st150 engine complete (wiring, Ecu , manifolds) how straight forward / difficult to swap?
Big shopping list or not so much? only looking at this engine beers same way round as me pinto
Thankssss
Mr C
posted on 5/6/15 at 07:43 PM Reply With Quote
I've not done a conversion as such, though built up a duratec for a mid engine application. I would think you'll need to change a number of parts including sump, bellhousing, and oil filter housing to clear your chassis. Check out Retroford for RWD conversion parts, also Raceline for a sump etc. The standard inlet is a bit pants tbh the throttle body is very restrictive though can be swapped out for a 60mm item. also the standard throttle is motorised so needs to be sorted. Best to throw away the manifold and look towards bike bodies or Jenveys if you can. Allow for a new exhaust as well. As you can imagine the cost can climb pretty quickly though the engines are cheapish to replace if you blow it up and with bodies and a cam swap good for around 200bhp.
All the best whatever you choose to do
Girl walks into a bar and asks for a double entendre, so the barman gave her one
davidimurray
posted on 5/6/15 at 07:54 PM Reply With Quote
Jut done it - some info her - http://locostbuilders.co.uk/viewthread.php?tid=192871
Will be £1k+ and lots to do but worth the grin factor!
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
ali f27
posted on 6/6/15 at 10:34 AM Reply With Quote
Have a look at rwd motorsport most of the parts are priced on their web site lots of time and money on my change were to bringing my car from webber carbs to injection if money is tight how about bike carbs and something simple for spark
