Author: Subject: Wanted Engine Crane
joneh
posted on 20/6/15 at 08:29 PM Reply With Quote
Wanted Engine Crane
After a foldable engine crane around the Southampton / Portsmouth area. Seen a few on the bay but thought I'd check here.
Jon
mark chandler
posted on 20/6/15 at 08:43 PM Reply With Quote
I,ve got one, £50 if that's any use, 20 miles up the m3.
The seals leak so you need to top up before use and bleed which is a pain, not expensive to replace the seals I have not used it for years now so have not bothered.
it's lifted a v12 jaguar engine in the past, plenty strong enough for most jobs.
Regards Mark
joneh
posted on 20/6/15 at 10:03 PM Reply With Quote
Regards Mark
Thanks, I'll leave that as option B for now if that's ok. I'd prefer one that doesn't need a fix, although seals blowing seems fairly common...
corrado vr6
posted on 20/6/15 at 10:07 PM Reply With Quote
Hi Jon
If it's just for a one off lift as I'm not looking to sell but I have a Clarke crane that I don't mind lending out for a bit
I'm based in Winchester SO21
Let me know if this helps you out
Greg
http://r1indy7.wordpress.com/
DanP
posted on 20/6/15 at 11:02 PM Reply With Quote
I'm in Lee on solent, not for sale but welcome to borrow.
Dan
joneh
posted on 21/6/15 at 08:50 AM Reply With Quote
Wow thanks guys, Dan I'm just around the corner from you in Titchfield Common so may take you up on that.
I'm still going to see if I can buy one for now as I can see this being an engine in out in out project taking a few months. I'm predicting the webers fouling the steering and all hosts of issues.
Jon
scudderfish
posted on 21/6/15 at 10:10 AM Reply With Quote
Also be prepared to lift the car to get the crane to fit underneath, and get a load leveller.
