Author: Subject: Ford LSD 3.6 diff oil
craig5
posted on 23/6/15 at 01:21 PM Reply With Quote
what oil is everyone using and how much does the diff require
mcerd1
posted on 23/6/15 at 01:36 PM Reply With Quote
Is this a sierra diff with the stock viscous LSD ?
[Edited on 23/6/2015 by mcerd1]
craig5
posted on 23/6/15 at 01:45 PM Reply With Quote
with 100mm flanges
CosKev3
posted on 23/6/15 at 01:49 PM Reply With Quote
Doesn't need lsd oil.
Just EP90 GL5 gear oil as the viscous lsd unit is sealed.
craig5
posted on 23/6/15 at 01:58 PM Reply With Quote
U know how much it needs
CosKev3
posted on 23/6/15 at 02:02 PM Reply With Quote
Can't honestly remember,1 litre springs to mind.
there's no drain plug though, you have to remove rear cover to drop oil.which is easier said than done if its never been off before!
craig5
posted on 23/6/15 at 02:06 PM Reply With Quote
There's a side level plug though?
CosKev3
posted on 23/6/15 at 02:09 PM Reply With Quote
On rear plate is level plug yeah
craig5
posted on 23/6/15 at 02:19 PM Reply With Quote
Kev you gone with the 5vy engine?
CosKev3
posted on 23/6/15 at 02:31 PM Reply With Quote
No mines a old carbed 5jj, with some headwork it did 164bhp on the rollers though
mcerd1
posted on 23/6/15 at 03:07 PM Reply With Quote
Approx. 0.9l of EP90
As above the viscous bit is a sealed unit so it doesn't need any special oil or additives
craig5
posted on 24/6/15 at 02:36 PM Reply With Quote
there torque setting for flange bolts when refitting?
brown_d9
posted on 30/6/15 at 07:55 AM Reply With Quote
We checked the Haynes manual and it mentioned that for our diff the oil level is a set distance lower than what we thought was a level plug (10mm lower springs to mind)
Is this an error?
Ours is a 3.62 LSD from an XR4X4 if that makes any difference.
[Edited on 30/6/15 by brown_d9]
