Author: Subject: Check out my knob.
furryeggs
posted on 29/6/15 at 08:39 AM Reply With Quote
Check out my knob.
This is the final Mk 3 version of my home made/machined gear knob, 316 grade stainless with a compression fit brass insert, finished with 400 grit to grain and 4 coats of clear coat. weighty but feels good and solid. Not sure on IVA though, It'll go on after.
[img][/img]
[img][/img]
Rosco86
posted on 29/6/15 at 09:33 AM Reply With Quote
looks good! if you had a 2.5mm rad on the top edge i think you will be fine for iva
My Build Thread
adithorp
posted on 29/6/15 at 11:37 AM Reply With Quote
...and the bottom edge.
http://jpsc.org.uk/forum/
furryeggs
posted on 29/6/15 at 11:46 AM Reply With Quote
I did have a 2.5mm radius on the first test piece but it didn't look right for what I was looking for.
SteveWallace
posted on 29/6/15 at 01:45 PM Reply With Quote
Easy solution - just use a cheap and nasty one for IVA and then put your nice shiny new one on afterwards.
splitrivet
posted on 29/6/15 at 05:48 PM Reply With Quote
My what a big one !!!
Years ago I used a polished piston from a moped in a model T rod I built which looked cool.
Bob
Angel Acevedo
posted on 30/6/15 at 01:13 AM Reply With Quote
Cant you use a Rubber foot tor furniture as temporary cover?
https://www.google.com.mx/search?q=regaton+de+hule&espv=2&biw=1517&bih=741&source=lnms&tbm=isch&sa=X&ei=qOORVYOYIIz2-QG6zY Nw&ved=0CAYQ_AUoAQ&dpr=0.9
Sorry, search is in español....
TheGiantTribble
posted on 30/6/15 at 08:03 AM Reply With Quote
Think of all that weight slowing the car down...
Looks great though.
furryeggs
posted on 30/6/15 at 09:03 AM Reply With Quote
at 14 1/2 stone a 350g gearknobs not going to make any difference.
