nichnachs
posted on 30/6/15 at 02:50 PM |
Newbie questions
Hi there,
I have just acquired a built chassis, a Ron Champion one - which has been painted (quite badly). Has anyone got a good method of removing the old
paint back to the bare metal so I can tidy it all up how I want it? Also once this is done - what would you guys say is the next stage, i.e which bits
should I be looking at building and fitting first.
Thanks guys, I look forward to sharing this journey with you!!
John.
dilley
posted on 30/6/15 at 02:56 PM |
May be worth getting a price on shot blasting.
Dick Axtell
posted on 30/6/15 at 04:36 PM |
Why in such a rush to strip your chassis? You will need to determine what additional brackets will be necessary, and where they'll be placed, so
you will than have to remove to paint locally to any weld area, clean it, and then re-paint to prevent corrosion. Shot blasting (and possible powder
coating) is done only after all those brackets are finished.
Which all goes out the window, if like me, you later change the engine (which I'm right in the middle of doing!!).
nichnachs
posted on 30/6/15 at 05:07 PM |
Yes I see what you mean about making mods and adding brackets etc, just thought this would be easier with a bare metal chassis, then paint it all
after? Just seemed to make sense to me, but maybe not. Done a few resto's on old Triumphs in the past and I always stripped things back before
starting anything. Shot blasting is probably a bit out of my price range so I was going to find a method of doing it myself to keep costs down.
Blueosis1
posted on 1/7/15 at 05:30 PM |
dippig it might be worth a go ,they usally coat it after wards aswell
mark
