Author: Subject: Pinto on Bike carbs
ALLAN 14
posted on 4/8/15 at 02:11 PM Reply With Quote
Pinto on Bike carbs
Hi Guys.
I am helping a friend to install bike carbs onto an 1800 Pinto,We have got the engine started but we have a slight
intermittent blow back on cylinders 1&2, We have got the tickover to about 1000 rpm.
The engine is running the standard Sierra ignition with the vacuum connected and a brake servo.
As it has been a long time since I worked on a Pinto,My next step is to check the timing and cylinder compression
before anything else, Am I heading in the right direction??.
I would be much obliged for any guidance.
Best Regards
ALLAN 14
jacko
posted on 4/8/15 at 03:53 PM Reply With Quote
Are the carbs balanced ?
and how have you got the vacuum connected to the manifold just to one carb or all ?
ALLAN 14
posted on 4/8/15 at 04:27 PM Reply With Quote
Pinto on Bike carbs
Hi Jacko.
Vacuum is tapped off at 1&4 not on a intake from each,I think that the front pair are getting more air than the rear,
but need to get a carb balancer to make sure, will also check the tappets at the same time.
Regards
ALLAN
jacko
posted on 4/8/15 at 06:30 PM Reply With Quote
The first thing is to get the carbs balanced and for a temporary vacuum join all 4 pipes from each carb inlet to a small cylinder and one pipe to the dizzy
this should help stop the vacuum pulsing the dizzy
i am not to sure about the brake vacuum pipe
You could just disconnect the dizzy and block the vacuum pipes but set the timing to 36dgrs thats what Bogg Brothers did to mine until i got a modified dizzy
