Author: Subject: Crash damaged Sylva Leader for sale
jonny5
posted on 27/8/15 at 02:52 PM Reply With Quote
1989 Swindon Sylva 400 (Sylva Leader) for sale. No engine or gearbox. Front drivers side wishbones bent. Spare body work. Car is Chevette based and was fitted with Fiat twin cam engine and matching gearbox. 2 axles available, 1.3 Chevette and HS Chevette. Need to clear out garage space so open to offers. Based near Colne Lancashire. Photos are already posted on JPSC forum.
Volvorsport
posted on 28/8/15 at 04:31 PM Reply With Quote
Cant find the photos, can you email them ?
www.dbsmotorsport.co.uk
getting dirty under a bus
big_wasa
posted on 28/8/15 at 04:49 PM Reply With Quote
https://jpsc.org.uk/forum/viewtopic.php?f=6&t=1384
Volvorsport
posted on 28/8/15 at 07:00 PM Reply With Quote
Cheers bud
Volvorsport
posted on 30/8/15 at 05:23 PM Reply With Quote
whats the difference between the std and HS axle ?
jonny5
posted on 30/8/15 at 05:57 PM Reply With Quote
standard 1.3 axle is 4:1 gear ratio, the HS axle is the same as fitted to Opel Mantas but is as narrow as the normal Chevette axle. Ratio is 3.44:1. The HS axle is quite a bit heavier duty, I acquired this for the 2 litre twin cam I was using as 4:1 gear ratio of the 1.3 axle was too low geared for a fairly standard 2 litre engine, I was soon running out of revs in top gear. The torque tube of the HS axle has been shortened slightly to fit the car.
Brylt
posted on 28/9/15 at 04:42 PM Reply With Quote
Is this still for sale mate.
Bryan
jonny5
posted on 28/9/15 at 05:14 PM Reply With Quote
Yes . Car is still for sale.
Brylt
posted on 28/9/15 at 08:41 PM Reply With Quote
Did you sort out the logbook issue with dvla mate?.
Bryan
jonny5
posted on 29/9/15 at 09:46 AM Reply With Quote
Log book sorted. Now back in my possession.
