Author: Subject: can you identify this brake disc?
posted on 27/8/15 at 05:56 PM Reply With Quote
What car make/model is this brake disc from?
Diameter 240 mm
Thickness 10 mm
Hub dia 135 mm
Stud pcd 108 mm (ford?)
Stud hole dia 13.5mm
Hub depth 34 mm
coyoteboy
posted on 27/8/15 at 06:12 PM Reply With Quote
Depending on what your datum is for measurement, sounds close to a fiesta disc?http://brakeparts.co.uk/#!/shop/FORD/FIESTA/89-96/FIESTA%203%201.8%20DIESEL%20inc%20VANS/Front%20-%20Brake%20Discs%20and%20Drums/BDS4439
posted on 27/8/15 at 06:26 PM Reply With Quote
Spot on, thanks........ but 16 mins to get a correct id, forum is slipping
liam.mccaffrey
posted on 27/8/15 at 06:35 PM Reply With Quote
linky here
Ive used this with much success in the past. Measure the overall height and you'll have it
Build Blog
Build Photo Album
ceebmoj
posted on 27/8/15 at 07:12 PM Reply With Quote
Are you planning on using with willwood handbrake calipers?
DapperRob
posted on 28/8/15 at 08:23 AM Reply With Quote
It's almost a match for the MGF rear disc, but PCD is off. Will keep looking.
posted on 29/8/15 at 10:55 PM Reply With Quote
Nope. Looking to sell these, 3 of the surfaces still have the maching marks so one disc is unused..
