Author: Subject: Rear Drum Brakes
Lander
posted on 30/9/15 at 05:35 AM Reply With Quote
Rear Drum Brakes
Hi All,
I am just trying to buy new brake shoes, pistons etc for my rear drums. I believe they are from a Sierra but the drums measure 200mm which seems smaller than the kits for Sierras I can find on the Bay. It is compounded by not knowing what car type they are off so can't do a normal search.
Can anyone point me in the right direction please.
Thanks, Ian
voucht
Contributor
Posts 229
Registered 22/5/11
Location 1
Member Is Offline
Photo Archive Go!
Building: Haynes roadster on the road since november 2014 bu
posted on 30/9/15 at 05:44 AM Reply With Quote
According to my repair and service manual, 1st Sierra 1300 and 1600 have 203.2mm diam. drums (only the 2000 has 228.6mm diam. drums)
So your drums might be from the first "small engines" models ?
Hope this can help
Sylvain
555
907
posted on 30/9/15 at 06:54 AM Reply With Quote
Apologies Sylvain for contradicting but I have the bigger 9" drums and they came off a 1.6 estate.
I bought the whole back end and discarded the bits not required.
The bigger drums are not needed IMHO and I ended up fitting smaller diameter wheel cylinders from
a Fiesta to tone them down a bit
Paul G
Dick Axtell
posted on 30/9/15 at 09:04 AM Reply With Quote
a Fiesta to tone them down a bit Cheers Paul G
Whereas I fitted smaller (8" ) drums, but added larger (22mm) wheel cyls. Seems to work OK, although I also fitted a PCRV (pressure conscious reducing valve) to the rear circuit.
SteveWalker
posted on 30/9/15 at 09:37 AM Reply With Quote
Definitely 8" drums on mk1 Sierra 1.3 and 1.6 hatchbacks. Caught me out when I first needed to replace parts of my rear brakes, as I'd bought my kit part built and the Sierra's V5 had the (correct) 2l engine on - turned out that the donor was a 1.6 and had had a (probably paper only) engine change. Front brakes are 2l versions!
Lander
posted on 30/9/15 at 10:37 AM Reply With Quote
Great thanks guys.
voucht
Contributor
Posts 229
Registered 22/5/11
Location 1
Member Is Offline
Photo Archive Go!
posted on 30/9/15 at 03:17 PM Reply With Quote
Paul G
Hi Paul,
No problem and no offend taken, I just copied what my (French) service and repair manual says... so I guess it is not very accurate
Sylvain
555
