Author: Subject: Multi Plugs for Front/Rear Lights
ChrisJ15
posted on 18/10/15 at 11:32 AM Reply With Quote
I want to use a single plug for each of the front and rears lights so it can be disconnected in one go when my front or rear clams are removed.
Ive used the 'superseal' plugs before but I need 7 pins for the rear and they only seem to go up to 6.
I've seen 'waterproof' plugs with more connectors on eBay but as none of the big electrical suppliers sell them I would expect them to be a bit dodgy.
Ive used the nylon 'mate-n-lock' connectors inside the car and I wonder I could use these with lots of silicone sealant to keep the moisture out?
CosKev3
posted on 18/10/15 at 11:45 AM Reply With Quote
Personally I would rather use a 4 and 3 pin superseal each side than use a non weatherproof 7 pin and silicone
posted on 18/10/15 at 12:23 PM Reply With Quote
Simplest solution is a trailer plug & socket £16 should find you 2 x plugs + 2 x sockets on ebay
blakep82
posted on 18/10/15 at 01:57 PM Reply With Quote
That's how I'm doing mine!
One 7 pin plug to the back light,
One 7 pin to the front lights,
One 13 pin for engine electrics, sensors, fans horn etc
________________________
RoadkillUK
posted on 18/10/15 at 02:52 PM Reply With Quote
Hi, I've used these for my front lights.
Ebay Link
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
posted on 18/10/15 at 08:08 PM Reply With Quote
Keep in mind normal Superseal connectors are only rated at 8 amps per terminal, so the headlights alone would occupy 6 ways.
Slimy38
posted on 18/10/15 at 09:04 PM Reply With Quote
Same here, seems quite a logical way to separate sections of the car. I wanted to figure out a way of bolting the connectors to the chassis though, at least one end. Probably a variation on how they're traditionally fixed on a tow ball maybe?
tims31
posted on 19/10/15 at 06:44 AM Reply With Quote
The ones I am using are rated at 14 amps so should be ok so long as you're careful of the earth return.
http://www.at-k.co.uk/users/twc/pdf/Superseal-Connector-Technical-Data .pdf
Build: http://www.martinsfurybuild.co.uk/
