Author: Subject: battery Isolation Kit any good?
baldthreads
posted on 21/10/15 at 06:20 PM Reply With Quote
I was looking for a Cartek GT Isolation Kit but have been told they give a lot of trouble anyone have or use similar?
Fatgadget
posted on 22/10/15 at 08:04 AM Reply With Quote
Whats wrong with a good old fashioned not to mention cheap as chips Autolec master switch?
steve m
posted on 22/10/15 at 01:57 PM Reply With Quote
This is what 99% of use use on kit cars etc,
UNIVERSAL CAR BOAT VAN BUS TRUCK BATTERY ISOLATOR DISCONNECT CUT OFF KILL SWITCH
theduck
posted on 22/10/15 at 02:27 PM Reply With Quote
At the money they sell for id stick with a traditional key!
baldthreads
posted on 23/10/15 at 07:51 PM Reply With Quote
I know what you mean doesn't make much sense pay more and get trouble
snowy2
posted on 24/10/15 at 06:53 AM Reply With Quote
unless your building a dedicated track car i dont see the point in fitting an isolation switch..
sometimes you are the pigeon, most of the time the statue.
posted on 24/10/15 at 09:31 AM Reply With Quote
Range hyperstores sell them very cheaply
Strange though seems Range are a handy place to buy bubble packed car electrical odds and ends.
Mr C
posted on 24/10/15 at 09:48 AM Reply With Quote
Not sure why it's called a kill switch, it doesn't kill the alternator so the engine would continue running if used in an emergency.
Girl walks into a bar and asks for a double entendre, so the barman gave her one
Fatgadget
posted on 24/10/15 at 11:14 AM Reply With Quote
The expensive solid state ones apparently are spark proof.I'm not sure though I would trust a semiconductor to isolate huge amounts of current other than instantaneously.
Easy to implement engine kill facility on cheap isolating switches such as the Autolec with a bleed resistor grounding alternator output.
907
posted on 24/10/15 at 11:20 AM Reply With Quote
I bought the one with brass connections & pin as opposed to "looks like copper but is actually steel."
I payed a little more but then I'm like that.
Why?
So that when I park those mothers that allow their little darlings to play with the switches don't flatten the battery.
Paul G
