Author: Subject: Polo rad - vertical?
tajgreidotu
posted on 15/11/15 at 09:05 PM Reply With Quote
Hi all,
Im sure there should be a reason but, is it possible to use the polo rad in vertical instead of horizontal?
Just checked and fits perfectly under the nose cone!
To good to be true?
gremlin1234
posted on 15/11/15 at 09:21 PM Reply With Quote
rads always used to be fitted with tanks at top and bottom, so should be no problem there.
ref: http://www.canleyclassics.com/heating-and-cooling/spitfire-full-width-radiator/
however,
1: it will leave the thermostatic switch as the highest point and no easy way to bleed it.
2: feeding and returning coolant at the top will cause issues.
craig1410
posted on 15/11/15 at 11:22 PM Reply With Quote
I would recommend against this as you will be fighting against the natural thermo-syphon effect and that will require more effort from the water pump. These radiators in normal upright orientation flow water in the top inlet and into the top tank before flowing across the top half of the core and into the opposite tank where the water can drop down into the bottom half before flowing across the bottom half of the core to the outlet and into the pump.
In the orientation you describe, the water will initially flow downwards which is in concert with the thermo-syphon effect you would get from water which is being cooled but then the water will get to the bottom and will need to be pumped upwards while continuing to cool. This is against the thermo-syphon flow and will resist the pump.
You're also going to have issues bleeding both halves of the upper (as in your photo) tank. One half you can probably bleed through the small bore pipe near what is normally the top hose but the other half of the tank has no provision for bleeding.
[Edited on 15/11/2015 by craig1410]
mark chandler
posted on 15/11/15 at 11:44 PM Reply With Quote
On my polo rad if you stick a wire down the inlet it hits a block halfway down, from this is deduce it's a radiator in two halfs so water crosses the top half then falls down and comes back on the lower half, fighting thermal movement.
If this is the case (high I believe it is running on its end should not be a problem as the water rising due to thermal climb will balance out water being pushed down so if anything will be easier on the pump.
The fan switch will be fine provided you have a header tank above the top of the rad as it will always be full of water.
I would not be concerned about twisting it 90 degrees.
Regards Mark
[Edited on 15/11/15 by mark chandler]
craig1410
posted on 16/11/15 at 12:07 AM Reply With Quote
Hi Mark,
You're right about the baffle across the middle of the tank linking inlet and outlet, that's what I was talking about above. However I think there is a flaw in your logic about the thermo-syphon effect.
You are correct that by having the radiator flowing as in the above photo will have a positive and negative effect on thermo-syphon which will cancel out to have no effect. HOWEVER, in a normal radiator orientation it will have a positive effect on thermo-syphon since the hot water is always cooling as it descends. This effect won't be as strong as it would be in a vertical cored radiator but there is still a net downwards movement of water as it cools even when the cores are horizontal. By having inlet and outlet at the same height, that effect will be removed and the water pump will need to pump harder for the same flow.
Hope this makes sense,
Craig.
gremlin1234
posted on 16/11/15 at 12:18 AM Reply With Quote
you will still need to bleed it on the initial fill
tajgreidotu
posted on 17/11/15 at 08:26 PM Reply With Quote
Thanks for the answers guys,
Its interesting to consider it as a possibility, but maybe to risky.
once I decide the engine ill go for, Ill see if its necessary.
Thanks again for your opinions!
craig1410
posted on 17/11/15 at 10:15 PM Reply With Quote
I think you'd be better off finding a radiator that matches your desired dimensions when used in its designed orientation. I used to have a database of radiator sizes on my old website - I'll see if I can find that data if you like.
jambojeef
posted on 18/11/15 at 06:04 AM Reply With Quote
Id disagree with Craig really - thermosyphonic effects on fluid flow are generally small compared to those from a car water pump.
If it fits, and (other factors aside) that is the dominant factor in your installation - do it.
As an example say that you have a 50C temperature drop across your radiator 100C in, 50C out - the difference in density between water at 100ishC and 50ishC is around 30kg/m^3.
So if one half of the radiator is at 100C and the other 50C and a polo rad has a capacity of 10L (?) then one half of the radiator has a mass 0.015kg greater than the other.
Without understanding your system I would guess that this kind of mass of water wouldn't present a significant increase in load for the water pump.
Bluemoon
posted on 18/11/15 at 07:34 AM Reply With Quote
The other thing to consider is the weight when full is now taken not by the original mounting points the studs, pointing out of the bottom, but now via the bosses. In the original application in the polo the weight is taken by the studs. There is quite a not of force on the rad when you go over a bump..
posted on 18/11/15 at 10:15 AM Reply With Quote
If you get a low coolant level you will get no circulation as the water pump will air lock.
With old fashioned vertical rad or a Polo rad mounted normally circulation would be maintained because the water pump will always be kept primed.
Ben_Copeland
posted on 18/11/15 at 10:42 AM Reply With Quote
Honda Civic radiator is tall and thin, the pipes are top and bottom. Might be a better solution for you.
You can just about see mine in this picture.
Engine Bay
Engine Bay
[Edited on 18/11/15 by Ben_Copeland]
Ben
Locost Map on Google Maps
Enter Your Details Here
Benzine
posted on 18/11/15 at 11:13 AM Reply With Quote
I had a polo rad mounted vertically on my kit car for about a year. It angled back too and was behind an intercooler. I tried my best to duct air into it but it couldn't cope with sustained runs up hills when on boost
posted on 18/11/15 at 02:35 PM Reply With Quote
I'm with jambojeef on this one although I'd like to see your working out as I make it 0.15 kg difference.
I don't believe the water pump is going to be bothered by this but when engine is stopped, I reckon the outlet side will have colder water so cause the water to circulate in the reverse direction, not that I can see that makes any difference.
In short, not many people have done this (Benzine has but has not said whether the problems also occurred when the radiator was fitted in the conventional orientation) so there is little or no information as to any problems in doing this.
So it may be ok or it may not. By all means give it a shot but be prepared to redo it; I would recommend correctly sized and orientated radiator to avoid any rework.
Benzine
posted on 18/11/15 at 03:02 PM Reply With Quote
I agree with that, I'd also add that I had a stock 306 turbo 'turned up' quite high so it wasn't running very efficiently (i.e. it was making extra psi but also making extra heat). It coped fine in traffic and pootling around country roads, just struggled when giving it some haricots. Unfortunately I can't compare standard orientation with the way I had it as I've binned it and using a different rad setup now.
craig1410
posted on 18/11/15 at 03:03 PM Reply With Quote
I've not done any calculations on the thermosyphonic flows but what sticks in my mind is something I read in a book about cooling the Rover V8 engine (which I have had some experience with as those who have followed my build will know...) where the author said that the top radiator hose must be as close to level or ideally higher at the front than the back because hot water doesn't like being pumped downhill.
I agree, the thermosyphonic flow is probably small compared to the water pump flow but at idle revs when you are perhaps more likely to overheat surely you want all the flow you can get. Perhaps even more importantly is to have that flow continue for a while after you turn off the engine to avoid hot spots in the cylinder heads.
I guess my caution is coloured by having several years worth of marginal cooling on my RV8 using the exact same Polo radiator as the OP. I recently cured this by fitting a 70mm thick alloy radiator but have tried various things over the years and had many spoiled journeys watching the temperature gauge closely. In my opinion there are enough uncertainties in locust building without introducing more of them.
Good luck to the OP if he does decide to try it, I hope it works for you.
Edit: This is the book I'm referring to:
[Edited on 18/11/2015 by craig1410]
posted on 18/11/15 at 03:32 PM Reply With Quote
There used to be a couple of websites where you can put in dimensions and it would suggest car make/model radiator but no longer working.
But there are sites that show radiator dimensions e.g. http://www.carcooling.co.uk/catalog/Car_Radiators-6-1.html so you would need to go through different ones to find one that fits in the space you have; the engine capacity should be close to your engine's.
If you do find one, check on ebay to see if an alloy version of it exists.
