Author: Subject: duratec v6 into mk3 capri??
toby916
posted on 26/11/15 at 12:35 AM Reply With Quote
ok so long story short. bought my mk 3 about 5 years ago, parked her up due to the economy thing, got a diesel
now i happen to have been given a ford cougar, running 2.5 duratec. and i want to fit it to my capri. searched the web over and over, no answers.
so im asking if anyone has seen this done? i know there will be problems. probably going to use an rx8 gearbox as probably a bit much for the type 9 to handle!
fabricating etc is not a problem already realised the intake is going to be fun
any info much appreciated, will do a build thread when its all done
If it ain't broke but kinda works. its broke.......
samjc
posted on 26/11/15 at 01:09 AM Reply With Quote
Unfortunatly i cannot offer help but i am very intrested to follow as i myself have a 2.5 v6 duratec to one day go into my kit. I have a rx8 gearbox that im going to sort a adapter for at some point in the near future. Intake would be good to see a bike carb setup for the grunt and appeal.
r1_pete
posted on 26/11/15 at 07:33 AM Reply With Quote
How about using the S Type Jaguar manual gearbox, I think its a Getrag 221.
40inches, on here, has just fitted a similar setup into his 7, and has done a fair bit of work on the inlet, he'd be worth chatting to.
posted on 26/11/15 at 11:51 AM Reply With Quote
You'll also need an S-type/AJ-30 sump. Despite there common roots, there are a surprising number of differences between the 2.5L Duratec and the AJ-30 lump in the Jag.
You'll also need an S-type/AJ-30 sump. Despite their common roots, there are a surprising number of differences between the 2.5L Duratec and the AJ-30 lump in the Jag.
40inches
posted on 26/11/15 at 12:47 PM Reply With Quote
The Getrag gearbox is tiny, barely enters the tunnel on a 7. A lot of the Mondeo parts will fit the AJ30, along with the X type bits.
Rob Allison
posted on 26/11/15 at 10:05 PM Reply With Quote
Problem with the 2.5 mondeo duratec is the water pump as in the pic.
As said the Jag 3.0 is better for the job.
Badger_McLetcher
posted on 27/11/15 at 12:06 AM Reply With Quote
An X-type sump should also work, and means you don't have the "chin" of an S-type sump. You'll need an S-Type oil cooler/engine mount though (a combined unit on the S-Type), unless you fabricate something yourself.
TBH a jag lump is pretty cheap and easy to get a hold of - I bought the entire car of mine for £500, and let's just say I've got a free engine and gearbox
If disfunction is a function, then I must be some kind of genius.
