Author: Subject: Aluminium Sheets - quantity?
tajgreidotu
posted on 2/12/15 at 06:30 PM Reply With Quote
Panels time is approaching and taking a look for alu sheets, quite expensive....
Question is, how mu do I need to order for all panels + floor? 3-4 sheets would be enough?
I made some rough counts and should be around 13m² of aluminium. Am I wrong?
Smoking Frog
posted on 2/12/15 at 08:48 PM Reply With Quote
If I remember right I used four sheets (2m x 1m x 1.2mm) + Floor. The arches, nose, bonnet and scuttle are fibreglass everything else is aluminium including all internal panels, sides, tunnel, dash etc. also bulkhead and a couple of panels underside.
posted on 3/12/15 at 09:37 AM Reply With Quote
It is going back a bit, but I did the inside of my MK Indy (less the floor) with 1 sheet of 1m x 2m x 1.2mm Ally sheet. From memory I purchased it from a local fab shop for around £30. They also had a guilotene and chopped it up for me so I could get it in my car for free
907
posted on 3/12/15 at 11:06 AM Reply With Quote
I used 8 2x1's……. but it's OK, I got it right in the end, sort of.
posted on 3/12/15 at 04:30 PM Reply With Quote
Floor, sides bulkhead, tunnel etc on my Striker was 2 x 8x4 sheets. Got them from the local well known window/shop fitter/boarder upperer...
loggyboy
posted on 3/12/15 at 05:07 PM Reply With Quote
Thats what I was supplied with also for the Striker, but being a smallish chassis I suspect it most 7esqs would need 3.
[Edited on 3-12-15 by loggyboy]
Mistral Motorsport
tajgreidotu
posted on 4/12/15 at 03:01 PM Reply With Quote
Thank you for your replies guys.
Following your comments, for Floor, side panels, bulkhead, tunnel, bonnet, scuttle, dash and bulkhead I should be looking for 6 sheets of 2x1.
I found a pretty cheap place today,
2*1 (1.5mm) -> 18gbp
2*1 (1mm) ->10gbp
Not sure how that sounds for UK prices, but here is half of my last quote....I guess they feel I'm foreign.
Javi
