Author: Subject: Zetec plumbing question
Lander
posted on 5/12/15 at 11:51 AM Reply With Quote
Dear Collective,
I am at the stage of plumbing in the engine for water on my build and have a quick query. I bought my engine, box, ecu from a running MK so should be straight forward drop in and connect up.
I am not using a heater so that outlet from Thermostat should be blanked off, already done.
However the top outlet (bleed pipe?) from the thermostat is also blanked off, well it has some sort of bleed nipple on it.
Also the outlet (19mm?) from the thermostat which should link into the "bottom pipe" is also blanked off.
Would this work with this set up ? Please discuss.
Thanks in advance, Ian
Dick Axtell
posted on 5/12/15 at 12:33 PM Reply With Quote
Check out this thread :-
http://www.locostbuilders.co.uk/viewthread.php?tid=200665
Paul Turner's reply was a sound guide.
Lander
posted on 5/12/15 at 02:54 PM Reply With Quote
Thanks Dick,
I had read that thread but I am bemused by the ports that are blocked off on my thermostat currently as it was on a running setup. So it is basically as Paul Turners image but without the Bypass pipe or the bleed pipe from the top of the thermostat and just wondered what thoughts were on that set up, would it work ?
Thanks,
Ian
Dick Axtell
posted on 5/12/15 at 03:28 PM Reply With Quote
Originally posted by Lander
Thanks Dick, I had read that thread but I am bemused by the ports that are blocked off on my thermostat currently as it was on a running setup. So it is basically as Paul Turners image but without the Bypass pipe or the bleed pipe from the top of the thermostat and just wondered what thoughts were on that set up, would it work ? Thanks, Ian
Hi Ian. Not 100% sure if your suggested variation to the Paul Turner plumbing diagram would work OK. Am still in the connecting up stages, and as its a tried and tested method, I'll stick with the Turner scheme as is. Nonetheless, I'll be interested to hear if your version works OK.
