Author: Subject: Spun Bearing Subaru Diesel
Irony
posted on 8/12/15 at 01:42 PM Reply With Quote
Work colleague broke down in his 09 Subaru 2.0 diesel. Its been diagnosed as a spun main bearing, repair cost £3500!!!! Anyone had any experience with this?
posted on 8/12/15 at 04:33 PM Reply With Quote
No experience as such, but I'd guess engine out, dismantle, line bore main bearing and new parts.
Would a 2nd hand engine not be cheaper?
posted on 8/12/15 at 05:00 PM Reply With Quote
Price sounds too cheap but I would have thought a new short engine or secondhand engine would be the minimum repair
Being as it is a model well off the mainstream good secondhand low mileage secondhand diesel engines even imported from Japan would be like gold dust.
ReMan
posted on 8/12/15 at 06:16 PM Reply With Quote
no experience but i recall seeing many diesel failures on the net when i was deciding what 4x4 to have and I fancied one of these but decided not to risk it
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
jelly head
posted on 9/12/15 at 08:17 AM Reply With Quote
Was at the local specialists getting our Impreza serviced and they had a Legacy diesel parked up outside.
I was asking the mechanic about it as i was considering one as our next motor and he said said that the bottom end had gone and basically it was scrap and was going to break it for parts as you couldn't get a short motor from anywhere, second hand motors go for big money if you could find one and Subaru would only sell you a full engine for mega bucks.
He also said it was pot luck with the engines whether they went, some go at low miles while others go on for ever , there didn't seem to be a common factor.
So that was me well and truly put off
SCAR
posted on 9/12/15 at 01:01 PM Reply With Quote
Just had a bearing spin on an Astra diesel. Got a good used crank, a new set of main and big end shells Cleaned everything up and the jobs all good £160.
posted on 10/12/15 at 09:55 AM Reply With Quote
Presumably you did the work yourself?
When you factor in labour cost of a garage it will be ££££
posted on 10/12/15 at 10:27 AM Reply With Quote
Just had a bearing spin on an Astra diesel. Got a good used crank, a new set of main aon nd big end shells Cleaned everything up and the jobs all good £160.
Even more so ££££££££££ on a flat 4 diesel
SCAR
posted on 10/12/15 at 01:52 PM Reply With Quote
That cost is for parts only. It took us a day to do and we took a chance as our time is free and the parts were cheap. Bet a Scooby replacement crank wont be as easy to find and while the job was easy enough on the Astra I don't think I'd like to attempt it on an 09 Scooby.
posted on 14/12/15 at 09:05 AM Reply With Quote
Agreed - 09 Subaru diesel could be a lot of work at home!
beaver34
posted on 14/12/15 at 09:53 AM Reply With Quote
i would assume its engine out and split the case
Irony
posted on 14/12/15 at 03:52 PM Reply With Quote
It's gone now anyway - he found a company will to buy it off him for £1000. Either that or scrap it.
posted on 16/12/15 at 09:35 AM Reply With Quote
Good, best gone and forgotten.
