Author: Subject: Throttle body heat insulation material
r1_pete
posted on 18/1/16 at 04:08 PM Reply With Quote
I need to make a heat insulator to go between my plenum and throttle body, for 2 reasons, 1 it'll help prevent heat soak to the IAT, and 2, it'll give me a touch more clearance.
I need something about 10mm thick, can anyone help with what material I need and any UK suppliers.
Cheers.
Pete.
theduck
posted on 18/1/16 at 05:41 PM Reply With Quote
PTFE would be ideal.
monkeyarms
posted on 18/1/16 at 06:29 PM Reply With Quote
Nylon or POLYPROPYLENE ect
http://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=p2050601.m570.l1311.R5.TR6.TRC2.A0.H0.X10mm+plastic.TRS0&_nkw=10mm+plastic+sheet&_sacat =0
[Edited on 18/1/16 by monkeyarms]
se7ensport
posted on 18/1/16 at 07:01 PM Reply With Quote
Try these guys http://www.ferriday.co.uk/thermal-products/
It worked out about £60 for my Duratec inlet manifold
gremlin1234
posted on 18/1/16 at 10:49 PM Reply With Quote
once upon a time they used asbestos for this, very good for the purpose, but later found to have significant disadvantages.
coyoteboy
posted on 19/1/16 at 12:06 AM Reply With Quote
Delrin, or maybe glass filled PTFE. Not raw PTFE or similar as it will have poor stiffness at higher temps.
HowardB
posted on 19/1/16 at 08:37 AM Reply With Quote
ptfe has a very high temperature capability, however it has low modulus and creeps very easily, that is why it is good as a thread sealing tape. Subject to the expected temperature, assuming that it is below 120C then Nylon could be used. Acetal/Delrin would work too. Despite working for a company that makes Nylon, I would probably be inclined to use a tufnol type material. A reinforced sheet laminate. This would be more stable and be less likely to degrade over time.
If you want some nylon drop me a PM I may be able to find some.
hth
Howard
r1_pete
posted on 19/1/16 at 12:48 PM Reply With Quote
Thanks for all the advice guys, I've done some googling using the keywords in the replies, came across a trend for using wooden spacers on V8 Carbed engines!!
Cotton phenolic sheet comes a close second to wood for thermal insulation, so I've ordered a £5 worth of Whale Tufnol, which seems have the right characteristics reading the specs.
Thanks again.
Pete.
posted on 19/1/16 at 03:53 PM Reply With Quote
Thinking back, my 2.0 Pinto was fitted with a Weber 32/36 DGV carb and had an insulation plate between the carb body and inlet manifold. Not sure what it was made of, but I kept it in place as I assumed it was meant to be there. Again working from memory it was brown in colour and appeared to be fibrous in nature.
wombat258
posted on 20/1/16 at 08:18 AM Reply With Quote
+1 for tufnol. Nylons, delrin and teflon will relax with heat.
atomic
posted on 22/2/16 at 10:01 AM Reply With Quote
A Phenolic resin sheet eg Tufnol (ideally Glass Fabric Tufnol) is the correct product to use.
r1_pete
posted on 22/2/16 at 11:30 AM Reply With Quote
Thanks, yes I got an 8mm sheet of Tufnol, and made the spacer.
I've got the engine running now, and the Air temperature doesn't move as the engine warms up, just what I needed.
