New Topic New Reply
Author: Subject: laser / water jet cutters
Volvorsport
posted on 3/3/16 at 11:41 AM Reply With Quote
I know it's been asked loads of times can anybody recommend the above...just want to get some prices.
www.dbsmotorsport.co.uk
getting dirty under a bus
Doctor Derek Doctors
posted on 3/3/16 at 11:48 AM Reply With Quote
I used these guys:
http://www.controlwaterjet.co.uk/
Great for small volume stuff, really good service
www.t89.co.uk
www.racecarwings.co.uk
callan@t89.co.uk
mcerd1
posted on 3/3/16 at 12:05 PM Reply With Quote
I used these guys before:
www.h2oprofiling.co.uk
'pathfinder' on here had something to do with them at the time - linky:
http://www.locostbuilders.co.uk/viewthread.php?tid=186146
[Edited on 3/3/2016 by mcerd1]
Ugg10
posted on 3/3/16 at 01:42 PM Reply With Quote
www.lasermaster.co.uk
Used them a couple of times for Aluminium (upto 10mm) and Steel, quick quote turn around and job done well and quickly (both *.dwg files I supplied)
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
watsonpj
posted on 3/3/16 at 05:44 PM Reply With Quote
another vote for lasermaster
balidey
posted on 3/3/16 at 08:12 PM Reply With Quote
As you are in Lincoln, not too far south from you in Spalding / Pinchbeck is Laserfab (part of Gutridge Engineering).
Not used them for laser work myself, as my company has our own laser workshop, but I have heard good things about Laserfab.
Dutch bears have terrible skin due to their clogged paws
dave_424
posted on 4/3/16 at 02:38 PM Reply With Quote
Doncaster laser were the cheapest around by far when I needed some parts cut out
SteveWallace
posted on 5/3/16 at 10:30 AM Reply With Quote
What sort of ball park prices do these companies charge? I need to make 4 mild steel thin quarter panels plus up to 6 smaller trim bits to skin the wood frame on my MG TC. I can buy the steel off e-bay and cut them myself with a saw using the ond rusty ones as templates, or I guess that I could get them water cut.
Its not a huge job to cut them myself, but if its not too much to get them water cut, I might go that route to save the job and get a neater finish (plus I guess that there will be a small saving in the unit cost of their steel stock that would off-set their price for the job a little bit).
coyoteboy
posted on 5/3/16 at 02:26 PM Reply With Quote
My experience is 50 quid set up charge, plus material, plus a repeating cost per part is about normal.
Volvorsport
posted on 5/3/16 at 02:58 PM Reply With Quote
I've got a manual plasma that would do that job nicely. If you have drawings , worlds your oyster.
John G
posted on 15/7/16 at 12:28 PM Reply With Quote
water jet cutting
Just had a very good job done by this company http://www.sussexstone.co.uk/ Based in East Sussex not far from Heathfield.
They cut cailiper mounting brackets as well as other bits and pieces. Just had to supply a DXF file with drawings, very helpful people
marc_cowley
posted on 21/7/16 at 04:41 PM Reply With Quote
these guys were really helpful and well priced
http://www.h2ocreations.co.uk/
C30 T5
New Topic New Reply
