Author: Subject: WANTED: 44mm 12 point (Bi-Hex) socket or cranked ring spanner
MK9R
posted on 17/3/16 at 09:24 AM Reply With Quote
Cant for the life of me find one that isnt a 6 sided impact socket!!!
Can any one help??
Cheers Austen
RGB car number 9
www.austengreenway.co.uk
www.trackace.co.uk
Pojo
posted on 17/3/16 at 09:34 AM Reply With Quote
How about this
FACOM K.44 3/4" DRIVE BI - HEXAGONAL ( HEX / HEXAGON ) (12 POINT) SOCKET 44MM
Very expensive though
MK9R
posted on 17/3/16 at 09:36 AM Reply With Quote
Lol just found that!! Annoying I have to cut it up as its too make a tool for the workshop. Can't even check itsvthe correct size without cutting it up.
And yes expensive, was hoping for some cheap poo as got to weld it on to an adaptor
[Edited on 17/3/16 by MK9R]
Cheers Austen
RGB car number 9
www.trackace.co.uk
Pojo
posted on 17/3/16 at 09:37 AM Reply With Quote
good luck
Rosco86
posted on 17/3/16 at 09:54 AM Reply With Quote
how about getting something laser cut instead?
My Build Thread
posted on 17/3/16 at 10:04 AM Reply With Quote
A shame you have to modify it
I've done that before and then realised I need the original tool.
theconrodkid
posted on 17/3/16 at 11:16 AM Reply With Quote
ill have a look in the dark corner of my garage later,does it have to be bihex?.
who cares who wins
pass the pork pies
rj
posted on 17/3/16 at 12:33 PM Reply With Quote
I got a 3/4 drive socket set recently, all 12 point sockets, £40 delivered off ebay. I will no longer be defeated by hub nuts !
MK9R
posted on 17/3/16 at 12:47 PM Reply With Quote
Has it got a 44mm though??
Cheers Austen
RGB car number 9
www.trackace.co.uk
tul214
posted on 17/3/16 at 01:03 PM Reply With Quote
A bit cheaper
1.6 Raw Super6 sold
MK9R
posted on 17/3/16 at 01:07 PM Reply With Quote
Originally posted by tul214
A bit cheaper
Brill thanks. Ordered
Cheers Austen
RGB car number 9
www.trackace.co.uk
theconrodkid
posted on 17/3/16 at 02:54 PM Reply With Quote
found it in the end tho 50mm may be a bit slack
who cares who wins
pass the pork pies
posted on 17/3/16 at 03:05 PM Reply With Quote
Now hub nuts are hard work - tight and need some muscle to loosen/tighten.
