Author: Subject: mk reverse
david
posted on 25/5/16 at 12:19 AM Reply With Quote
mk reverse
is the mk reverse starter just held on with two points or is there anything underneath the the starter
Toprivetguns
posted on 25/5/16 at 05:34 AM Reply With Quote
I welded two thick 5mm plates to the chassis that acted as uprights for the starter motor to bolt to.
Not much need for support underneath if it's fastened correctly.
Have a look a my YouTube video, hope this helps.
http://youtu.be/7GfBVKb60Fg
Only drive as fast as your angel can fly... !
CosKev3
posted on 25/5/16 at 07:01 AM Reply With Quote
Will all depend if it's been fitted by MK when they built the chassis?if so then yeah just two mounting points.
