New Topic New Reply
Author: Subject: westfield or Locost chassis?
alfas
posted on 27/5/16 at 02:25 PM Reply With Quote
is this a westfield pre-lit chassis (alloy bodied pre-lit)?
[Edited on 27/5/16 by alfas]
Smokey mow
posted on 27/5/16 at 05:29 PM Reply With Quote
Its not an alloy bodied pre-lit. The arrangement of the engine bay tubes are completly wrong and bare no resemblance.
alfas
posted on 27/5/16 at 06:30 PM Reply With Quote
thats what i thought too. locost?
here interior:
alfas
posted on 27/5/16 at 07:25 PM Reply With Quote
front wishbones look like westfield (i have further pics), interior width is 395mm measured from propshaft tunnel to entry...so from that point of view it would match with a westfield.
dash looks locost-ish, bonnet looks too wide for a westfield
Smokey mow
posted on 27/5/16 at 09:12 PM Reply With Quote
Wishbones look similar to current westfields but on prelits they were U shaped not V shaped
Engine bay, tunnel, headlamp mounts and nosecone tabs are completely wrong though
This is what an alloy prelit looks like
http://forum.wscc.co.uk/forum/index.php/topic/117001-pre-lit-ally-bodied-build-thread/
alfas
posted on 27/5/16 at 10:11 PM Reply With Quote
"Wishbones look similar to current westfields but on prelits they were U shaped not V shaped"
yes i know...but it neither looks like a locost...
very strange car
alfas
posted on 28/5/16 at 10:29 AM Reply With Quote
finally we found a chassis number on a little plate welded on the typical westfield area (crossmember in front of engine).
the plate has the correct size, the same welding as the rest of the chassis, its powedercoated and the numbers are the correct size as westfield used them
it has a 1987 SE chassisnumber.
New Topic New Reply
