Author: Subject: Recommended Impact adhesives
Daddylonglegs
posted on 1/6/16 at 02:28 PM Reply With Quote
Hi all,
Can anyone recommend a good impact adhesive for sticking vinyl trim on to metal/wood?
I have tried several so-called 'strong' ones but they are cr*p and the material starts to lift at the slightest hint of temperatures above 50 deg Fahrenheit!!
Thanks,
JB
Smoking Frog
posted on 1/6/16 at 03:27 PM Reply With Quote
The spray-on adhesive that carpet fitters use worked for me (will check name on can if needed). I've had no problems but it's never been in direct sunlight as yet. Normally I would suggest evo-stick as a good contact adhesive, but if it's solvent based it might eat into the vinyl. Although I think evo-stick is also available in non solvent form now (not sure).
posted on 1/6/16 at 03:41 PM Reply With Quote
I made my own dashboard out of black vinyl covered plywood. I used carpet fitters aerosol adhesive and never had an issue with it loosening even in direct sunlight.
posted on 1/6/16 at 03:44 PM Reply With Quote
I used a spray contact adhesive I bought from a local upholsterer - I bet it's much the same as the carpet stuff. Sticks like the proverbial, even though the seats have got quite hot in the sunshine (remember sunshine?).
