Author: Subject: Wiring a Smiths RVC rev counter
Mash
posted on 8/6/16 at 09:33 PM Reply With Quote
Managed to get this cheap on fleabay
[img] Smiths Rev counter
Smiths Rev counter
[/img]
but struggled to find out how to wire it up for coil/dizzy. Sussed it eventually but the web/google wasn't massively helpful. so here's the back
rev counter rear
rev counter rear
A = connect to the -ve side of the coil (side that goes to distributor)
B = connect to the +ve side of the coil
C = ground
That works for me anyway
alfas
posted on 14/6/16 at 09:15 AM Reply With Quote
http://www.gomog.com/allmorgan/smithsclassic.html
[Edited on 14/6/16 by alfas]
Mash
posted on 10/8/16 at 08:21 PM Reply With Quote
Thanks alfas, yes I found that diagram, and lots of other similar ones, but it doesn't relate to whats on the back of the tacho, so I eventually worked it out by trial and error
r1_pete
posted on 10/8/16 at 10:52 PM Reply With Quote
Correct wiring is
A - points side of coil.
B - switched live
C - ground
Coil + is switched live, so you'll be ok.
