Author: Subject: Dyno print, spot the errors.
Nickp
posted on 24/6/16 at 10:01 PM Reply With Quote
A car a mate's considering buying.
Dyno print seems to contain 'errors' (no reflection on the seller btw)
I spotted 3, any more?
Slimy38
posted on 24/6/16 at 10:25 PM Reply With Quote
How does a torque vs horsepower graph have five crossing points?
femster87
posted on 24/6/16 at 10:47 PM Reply With Quote
On a different scale
jeffw
posted on 25/6/16 at 05:58 AM Reply With Quote
Put power is the calculated figure, it is a product of rpm and torque measurements. So if the torque and rpm don't dip how does the power?
[Edited on 25/6/16 by jeffw]
jelly head
posted on 25/6/16 at 08:21 AM Reply With Quote
Yeah and because it's calculated shouldn't the two curves cross at 5252rpm?
posted on 25/6/16 at 11:24 AM Reply With Quote
Only if torque and HP are on the same scale, which they are not. Torque and HP have the same value at 5252RPM if you look closely (around 136 bhp / lbft)
phelpsa
posted on 25/6/16 at 11:33 AM Reply With Quote
Torque is the calculated figure. Dynos measure power.
Slimy38
posted on 25/6/16 at 12:26 PM Reply With Quote
Nope, on any scale it should still only cross once. If the scales are different then they won't cross at 5252, but it should only ever cross once.
phelpsa
posted on 25/6/16 at 12:34 PM Reply With Quote
The likelihood is that the 'smoothing' factor applied to each graph is different.
Nickp
posted on 25/6/16 at 12:38 PM Reply With Quote
Never seen it done on different scales before, makes it look odd.
What about only 11bhp transmission loss? It's a Westfield with a type 9 and Sierra LSD.
And why would they run it at over 150mph on the rollers?? Every one I've ever been to have only used 3rd or 4th gear.
posted on 25/6/16 at 12:48 PM Reply With Quote
A chassis dyno measures torque at the wheels, either directly via a brake (water, eddy current etc.) or indirectly on an inertia dyno via the acceleration of the drum.
Torque at the engine is then calculated using transmission loss etc.
[Edited on 25/6/16 by MikeRJ]
phelpsa
posted on 25/6/16 at 12:54 PM Reply With Quote
It measures energy at the brake, not torque. The torque is then found by dividing the energy per second (power) by the engine speed.
Nickp
posted on 25/6/16 at 12:56 PM Reply With Quote
Also, it's a std Vauxhall Red Top with ITBs, DTA ECU and an exhaust.
Peaking at over 7200rpm? Surely it'd peak lower than that and struggle to top 180bhp?
Andy D
posted on 25/6/16 at 05:49 PM Reply With Quote
I reckon it peaked at about 6200rpm, 182bhp?.. the last little kick upwards is a glitch of some sort. I'm sure rolling road operators will know what caused it? Unloading the dyno early or something like that he guessed? ;-)
Phil_1471
posted on 25/6/16 at 06:27 PM Reply With Quote
sarcastic comment retract to my own inaccuracies lol
[Edited on 25/6/16 by Phil_1471]
You can live in a car but can't rally a house
coyoteboy
posted on 30/6/16 at 07:04 AM Reply With Quote
Depends on the dyno in question. Plenty use an eddy brake and reaction arm to directly measure load. No idea about this specific one though. Measuring power out directly would by definition be harder and lies accurate.
Nickp
posted on 30/6/16 at 07:28 AM Reply With Quote
Yeah, I'd agree. 182 @ 6200 would be about right for flywheel bhp.
posted on 30/6/16 at 07:46 AM Reply With Quote
No, it measures torque at the brake, typically using a load cell on a modern dyno.
[Edited on 30/6/16 by MikeRJ]
jeffw
posted on 30/6/16 at 08:14 AM Reply With Quote
Yes, torque is the measured figure not power in most dynos.
Power (HP) = (Torque (lb-ft) x RPM)/5250
phelpsa
posted on 30/6/16 at 08:46 AM Reply With Quote
Whether it's sensing load at the end of a lever, hydraulic pressure or voltage, as well as speed at the brake, what the dyno is measuring is power. It has no idea how that power is being generated or transfered elsewhere in the system.
coyoteboy
posted on 1/7/16 at 02:26 PM Reply With Quote
There's a critical difference though, it's MEASURING torque and RPM. It's calculating power from that. If it measured voltage/current it would have an additional unknown (conversion in itself, losses in itself etc). If it measures torque at an arm and RPM it knows precisely the input power and it's really easy to do. I don't think anyone was arguing with the second half of your comment. My point was simply that your statement wasn't technically accurate from my experience with them. And this statement:
is wrong.
Dynos measure torque.
