Author: Subject: Maximum number of U J's?
the_big_1
posted on 27/6/16 at 11:39 AM Reply With Quote
Hi Guys,
Is there a limited number of U J's that can / should be used on a steering shaft.
I know common sense of as less as possible.
The setup I have made so far has two between the steering column and a shaft that's fitted to a bearing on the chassis, then two from the opposite side of the bearing down to the steering rack.
cheers
Mr Whippy
posted on 27/6/16 at 11:49 AM Reply With Quote
nope, just need to use good ones to reduce any play in the system.
the_big_1
posted on 27/6/16 at 11:51 AM Reply With Quote
Great stuff.
Feels nice and tight as it is now.
peter030371
posted on 27/6/16 at 12:17 PM Reply With Quote
Ask jeffW to post a piture if his new steering column......its a sight to behold and probably not out of place on a tractor (but I grant you it seems to work quite well)
adithorp
posted on 27/6/16 at 01:04 PM Reply With Quote
It's certainly not under-engineered.
http://jpsc.org.uk/forum/
Dick
posted on 27/6/16 at 02:30 PM Reply With Quote
Jeffs works well and was the only way to get from the steering wheel to rack with the new pedal box and the plen chamber, Yes heavy duty but no play and it works as it should. Quality Steering joints are not cheap or small unless you want play in them
the_big_1
posted on 27/6/16 at 05:26 PM Reply With Quote
Hi guys, this is mine so far. Do you think I should add a second bearing directly after the first, towards the rack or is the one enough?
[img]http://[/img]
paulc
posted on 27/6/16 at 06:46 PM Reply With Quote
Can't remember where I saw it, but i saw a recommendation that the number of support bearings should be the number of UJs minus 2.
So 1 bearing for 3 ujs, 2 bearings for 4 and so on.
I'll see if I can dig out where I found it.
Found it:
http://www.hotrod.com/how-to/additional-how-to/custom-steering-system/
[Edited on 27/6/16 by paulc]
Dick
posted on 27/6/16 at 06:54 PM Reply With Quote
You need to fit another support bearing to the shaft that you have fitted one to all ready for the best results , they need to be as far apart as possible
[Edited on 27/6/16 by Dick]
the_big_1
posted on 27/6/16 at 06:59 PM Reply With Quote
Great stuff!
I have managed to move the forward uj (Closest to bearing and towards steering rack) closer to the bearing so my plan is to either get a bearing that can mount to the spline area or extend the tube to cover up more spline and mount the bearing to the extended tube.
ReMan
posted on 27/6/16 at 07:42 PM Reply With Quote
I'd agree on that, the one bearing looks to be self aligning too?
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
the_big_1
posted on 27/6/16 at 07:48 PM Reply With Quote
Yep aggreed. I have ordered another bearing to add support.
Many Thanks!!!!!
