Author: Subject: 13" wheels with Mx5 1.8 brakes & uprights
lukebalmforth96
posted on 12/7/16 at 10:24 AM Reply With Quote
Does anybody with a Vortx use the mk1 1.8 running gear with 13" wheels?
I've seen some people saying only the 1.6 brakes will fit and with the Haynes build people have issues with the uprights. I'm wondering if this is the same with the Vortx.
I'm hoping to run CXR's with an et24.
Luke
[Edited on 12/7/16 by lukebalmforth96]
micksalt
posted on 13/7/16 at 02:23 PM Reply With Quote
I am also interested in finding out this information. I have the 1.8 brakes, but if I were to use the 1.6 caliper brackets at the rear (this is the only difference between the two) and the Flyin Miata Little Brake front brake kit up front, apparently 13" is possible.
AdamR20
posted on 25/7/16 at 08:52 AM Reply With Quote
Not on a kit car, but I use 13" wheels (two different sets, to be precise) on my 1.6 MX-5 track car. Fits nicely, brakes have more than enough power. Will be using the same brake setup for that thing in my avatar <<
[Edited on 25/7/16 by AdamR20]
micksalt
posted on 25/7/16 at 09:03 AM Reply With Quote
Adam,
Do you mind sharing the make, model and spec of the 13" wheels that you have used successfully?
Mick
AdamR20
posted on 25/7/16 at 12:24 PM Reply With Quote
Ooh, errrrrrmm.... I'll have a look!
One set is the cheapest steelies I could find on Oponeo, the others are some weird looking 5 spoke things I got for free
Ok, steelies are these: http://www.oponeo.co.uk/steel-wheel/magnetto-wheels-mw-r1-1213 (£28 when I got 'em though!).
The others appear to be Compomotive MOs (or at least a copy of), 13x6", unsure of exact offset but I'd guess in the region of 35-45: https://www.google.co.uk/search?q=compomotive+5+spoke+13%22&client=firefox-b-ab&source=lnms&tbm=isch&sa=X&ved=0ahUKEwib_6qe0I7OAhW ECcAKHXEgAOYQ_AUICCgB#tbm=isch&q=compomotive+MO
